monkeyboy Posted November 15, 2003 Share Posted November 15, 2003 hello, i have a problem... when importing models out of CAD into MAX, every object created in the same layer receives the same texture. Does this mean i have to create for every single object another layer in CAD so i have full control in max with textures? or are there any parimeters when importing? thnx Link to comment Share on other sites More sharing options...
Vince Paske Posted November 15, 2003 Share Posted November 15, 2003 You can play around with the import settings to derive objects by "entity" or "convert to single objects". You'll probably end up with a bunch of ojects in your scene labelled "3dsolid01" or 3dface01", which makes organizing your model difficult. Or you could bring it in the way you are now, add an "edit mesh" modifier and use multi/sub-object materials. I always separate the layers in my AutoCad model according to material beforehand, then I use the file-link manager to bring the model into Max. Depends on your work environment though. Link to comment Share on other sites More sharing options...
monkeyboy Posted November 16, 2003 Author Share Posted November 16, 2003 thnx calvin, but where do i find that file link manager? i've searched in the utilities panel but there is no such thing. Link to comment Share on other sites More sharing options...
Vince Paske Posted November 16, 2003 Share Posted November 16, 2003 Ah...I forgot to mention that you need the design extensions for Max 5 for the FLM. If you're using Max 6, it's not in there...yet. Sorry Monkeyboy. Link to comment Share on other sites More sharing options...
