Material ID question
Craig Ramsay
I am using Max 9 (64x) and it just let me create a Multi/Sub-Object material with 1000 slots.
Maybe your file is corrupt? Have you tried creating the material you want in a new scene?
Thats not what he is asking.
In the material slot, you can select its material ID (see image below).
I would like the to know the answer too, hence why Im chimming in. AND Id like to know how many different numbers of Object ID youre allowed.
Hmmm I wonder why it's limited to 15, it would have been a much better idea if you could just type a number in there rather than have the silly pull out menu. Does anyone know if this is something that can be scripted or is it actually a limitation of Max?
The numbers 0 - 15 strongly imply that they dedicate 4 bits to it somewhere. The other half of that byte is probably being used for something else.
