chow choppe Posted November 18, 2008 Share Posted November 18, 2008 (edited) Hi everyone can anyone please tell me how to make an animated fountain like this(the attached is a although a still) whose starting point is a small sized than the one where it meets water. Also its along a curve. I am not very good with animation. I am using max2008 and VRAY. And howto assign material to the falling water from this fountain have been using RPc fountains till now so have never used animated fountains inside max Kindly help me learn the process Thanks Edited November 18, 2008 by 3dsmaxed Link to comment Share on other sites More sharing options...
amer abidi Posted November 18, 2008 Share Posted November 18, 2008 look into particle systems in the max help rollout. Fairly simple and straightforward to startup, then it depends on your creativity and/or desired effect. Link to comment Share on other sites More sharing options...
Frosty Posted November 18, 2008 Share Posted November 18, 2008 Those look like an image or image sequence mapped onto a curved plane to me, not particles. Link to comment Share on other sites More sharing options...
whori Posted November 18, 2008 Share Posted November 18, 2008 Those look like an image or image sequence mapped onto a curved plane to me, not particles. yeah but this whole image is horrible Link to comment Share on other sites More sharing options...
Claudio Branch Posted November 18, 2008 Share Posted November 18, 2008 Real Flow Link to comment Share on other sites More sharing options...
Frosty Posted November 18, 2008 Share Posted November 18, 2008 yeah but this whole image is horrible Ha! i didn't say it was well done.... just how I thought it was done. With a little care and a bit of smoke and mirrors, a mapped surface can work well. Link to comment Share on other sites More sharing options...
chow choppe Posted November 19, 2008 Author Share Posted November 19, 2008 Those look like an image or image sequence mapped onto a curved plane to me, not particles. i mentioned that it is a still image but i want to make an animated fountain like that in my animation Link to comment Share on other sites More sharing options...
whori Posted November 19, 2008 Share Posted November 19, 2008 so go for particles:) Link to comment Share on other sites More sharing options...
chow choppe Posted November 19, 2008 Author Share Posted November 19, 2008 3 things: how will i make it start from a narrow point and grow into bigger size as it falls down secondly how to texture it so that it looks realistic. do i give them same material as my water third, How do i animate the water below it so that i get natural effect of the falling water merging into the water body and not appearing as if its falling on the floor and bouncing back Thanks Link to comment Share on other sites More sharing options...
Frosty Posted November 19, 2008 Share Posted November 19, 2008 i mentioned that it is a still image but i want to make an animated fountain like that in my animation Using a mapped surface for a still or animation is basically the same process. The only difference would be using an image sequence for the map instead of a single image. I would likely try to use particles for the splashes, but I would def use a mapped curved surface for the actual water flow. Link to comment Share on other sites More sharing options...
Nic H Posted November 19, 2008 Share Posted November 19, 2008 i reckon just get in there and experiment! nothing to lose. try particles, or geometry mapped animated textures (noise in bump with a stretched animated UVW might work) Link to comment Share on other sites More sharing options...
amer abidi Posted November 19, 2008 Share Posted November 19, 2008 plenty of tutorials on the web.. not to mention the magic button, F1 there one i remember for creating waterfalls on evermotion.org.. lemme go grab it for you... here you go.. http://www.evermotion.org/index.php?unfold_exclusive=251&unfold=exclusive hope it helps. Link to comment Share on other sites More sharing options...
chow choppe Posted November 20, 2008 Author Share Posted November 20, 2008 thanks a lot to everyone Link to comment Share on other sites More sharing options...
