whori Posted November 18, 2008 Share Posted November 18, 2008 Hi everyone, maybe anyone got any suggestions on making material with vray that will look wet..like wet road, asphalt or something.. Thanks Link to comment Share on other sites More sharing options...
BrianKitts Posted November 18, 2008 Share Posted November 18, 2008 making things wet is all about the reflection. Make yourself a patchy, splotchy black/white map for the reflection channel of your material, then just have some fun playing with the contrast and size of the map.. google = always good for reference images.... http://swedish.wunderground.com/data/wximagenew/g/gemini/1227.jpg Link to comment Share on other sites More sharing options...
whori Posted November 18, 2008 Author Share Posted November 18, 2008 BrianKitts said: making things wet is all about the reflection. Make yourself a patchy, splotchy black/white map for the reflection channel of your material, then just have some fun playing with the contrast and size of the map.. google = always good for reference images.... http://swedish.wunderground.com/data/wximagenew/g/gemini/1227.jpg hey thank you ! Link to comment Share on other sites More sharing options...
whori Posted November 18, 2008 Author Share Posted November 18, 2008 BrianKitts said: making things wet is all about the reflection. Make yourself a patchy, splotchy black/white map for the reflection channel of your material, then just have some fun playing with the contrast and size of the map.. google = always good for reference images.... http://swedish.wunderground.com/data/wximagenew/g/gemini/1227.jpg oh yes, and there is a problem then tiling the bitmap...because that reflaction map tiles with it..but it shouldnt ;/ Link to comment Share on other sites More sharing options...
danb4026 Posted November 18, 2008 Share Posted November 18, 2008 Put the reflection map on a different map channel and add another uvw map to the object with the new channel selected and map as you want, separate from the diffuse map mapping. Link to comment Share on other sites More sharing options...
whori Posted November 18, 2008 Author Share Posted November 18, 2008 danb4026 said: Put the reflection map on a different map channel and add another uvw map to the object with the new channel selected and map as you want, separate from the diffuse map mapping. thanks, never thougt about that Link to comment Share on other sites More sharing options...
Thablanch Posted November 19, 2008 Share Posted November 19, 2008 I'm using the procedural planet map, turning continents and water to black and white ( in the reflection slot, of course), you can play with sizes, amounts, and the way that the water dries down near the asphalt.. no tiling and quite a lot of flexibility.. here is an example of what I did with that: http://features.cgsociety.org/newgallerycrits/g74/161274/161274_1144666867_large.jpg Link to comment Share on other sites More sharing options...
whori Posted November 19, 2008 Author Share Posted November 19, 2008 Thablanch said: I'm using the procedural planet map, turning continents and water to black and white ( in the reflection slot, of course), you can play with sizes, amounts, and the way that the water dries down near the asphalt.. no tiling and quite a lot of flexibility.. here is an example of what I did with that: http://features.cgsociety.org/newgallerycrits/g74/161274/161274_1144666867_large.jpg hey this one is great! thanks Link to comment Share on other sites More sharing options...
