mbr Posted July 19, 2003 Share Posted July 19, 2003 I am curious what people use for their renderings? 35mm, 24mm, etc. Particularly for interior animations. Thanks. Link to comment Share on other sites More sharing options...
Jennifer Posted July 20, 2003 Share Posted July 20, 2003 Hi, A 50mm lens is commonly used in photography because the perspective it produces is very close to what the human eye sees. For a walk-through, though, it often does not give you enough peripheral vision to see the things you may want to see. The problem with smaller-mm lenses is that, although they give you a wider field-of-view, they distort the perspective, and animations can be uncomfortable to watch. For still-images a lens below 35mm can be okay, but I would be cautious with animations. Perhaps create a preview AVI with 35mm, the default 43mm and 50mm and see what you like. Have fun! Link to comment Share on other sites More sharing options...
sergio rocha Posted July 20, 2003 Share Posted July 20, 2003 hi mbr, in interiors i always use 28mm.it´s the best aproach for the livin space.There are many discussions about the best aproach to the human eye from 35 to 50mm, but as a visuallizer you should add the feeling of being in the space.Try pic a photo from a living room and be there at the same time.you´ll understand then. As for exteriors, you should go like 28-50mm. when needed, the "tecnhical camera" script can help you a lot to correct perspective. This works on stills.For animations i agree with jennifer. Link to comment Share on other sites More sharing options...
mbr Posted July 20, 2003 Author Share Posted July 20, 2003 Thanks. I'll go with the 28mm. It's a condo, so it's tough to get into the bathrooms with anything larger. I was using a 24mm, but I can see how that could distort things too much. Link to comment Share on other sites More sharing options...
mauarduz Posted August 4, 2003 Share Posted August 4, 2003 i use the camera that best suits the scene, i start modelling in perspective, and when i have the model quited advanced, i star to place the cameras, i often do interiors with 15mm and use the camera correction modifier Link to comment Share on other sites More sharing options...
STRAT Posted August 5, 2003 Share Posted August 5, 2003 i use different for each time. whether i use a telephoto for minimising paralax, super wide angle for qtvr's or a 'normal' 35mm for standard work, i pick and choose for each job. generally 50mm or 35mm for externals, and 32-26mm for internals Link to comment Share on other sites More sharing options...
mbr Posted August 5, 2003 Author Share Posted August 5, 2003 Thanks for the replies. 26mm seems to be good for this project. It's always nice to show more, but I don't want to skew the scale too much. Link to comment Share on other sites More sharing options...
