Glass Transparency in photomontage
Sketchrender
I have a problem with photomontages and glass transparency.
I generally set the view up with the photo in the back ground.
I take it out to render the image, but I do not get the transparency i want in the glass, and reflection of the the glossy objects also.
Where there is a lot of glass say bus shelter for example.
Do any of you have a general tip for this please.
Thank you
phil
- What blending mode are you using in photoshop to put the image behind the glass? It usually works quite well in overlay.
You can render a separate pass of reflections, to adjust in post.
(selecting the requires areas of the reflection pass only)
Hope it helps
