imported dwg lots of objects and high memory use
SgWRX
hi. i have max9. i've imported a dwg file and it has many many lines. one of the elevations has about 5000 individual lines. all in all, when i look at task manager, max shows it's using about 680mb of memory and my system only has 2gb of ram. viewport performance is slow.
anyway, i've created a copy of the scene, deleted all but one elevation and started attaching the lines. memory use jumps up to 1.5gb or so, then i save and close the scene, it's smaller, reopen attach more lines. seems like a lot to go through.
i don't have autocad or autocad LT, any ideas or do i just need to trudge through it to try and get all the lines as one object.
thanks
steve
You might also want to try turning off the undo's, and then connecting the lines. You might find that you can attach all the lines at once this way because max only has to attach them, and not remember how to unattach them.
thanks. actually i did reduce the number of undo's to 3, but yeah why not turn them off altogether.
In case it wasn't obvious - are you sure you need all those lines? Need to run flatten in ACAD? Are someof them hatches or other unnecessary detail?
no i'm sure they're not all necessary. that's the next part, cleaning up! drat! can't wait to build it though :)
Edited by SgWRX
