Has any here tried the Fry Render engine?
Michael J. Brown
I'd make this post in the Fry Render thread, except that I seriously doubt anyone other than the 1 or 2 Fry Render devotes 'viewing' at any given time would even see it.
I'm just discovering Fry Render and was wondering if anyone here had tried the demo - or even better yet, has worked extensively with it.
I can see from product samples shown on their website that the end results (supossedly achievable) are no less stunning than those produced in Mental Ray or V-Ray. And they boast the ability to be viewable in real-time (via another of their software add-ons).
What are the biggest pros and cons you encounter with it?
I've only played a little with Fry Demo, it seems like a really cool render engine, but with physically based render engines you have to expect some serious render times!
Im obviously no expert, and I'm sure you can achieve some amazing results, but i prefer V-ray personally, just because it has a great balance between quality and render time.
... i prefer V-ray personally, just because it has a great balance between quality and render time.
Speaking of which - and I fully entend on possing this question in the V-Ray forum for more in-depth discussion - Do you find it a challenge to get per-frame render times to a reasonable value when doing animations with V-Ray?
I've got a bit of a delema. I'm still pretty new to V-Ray and have been able to generate some fantastic results with it. I'd like to start doing all my animations at no less than 1080wide with it. However, I can't help but be discouraged by the markedly long render times i'm getting with V-Ray versus Mental Ray on many of my stills. I know there's got to be a perfect mix of variables such as using saved solutions and whatnot. But I'm just afraid I won't be able to skinny down 2.5hr render times to 15min.
If you are looking fro a render engine to do fast frames for animation and you already have a vray license.....
Alternatively you could look at Mental Ray. However (depending on the firepower you have by means of a render farm) I dont think an unbiased solution is what I would recommend for animation work. In fact, Ive never seen an animation done in Fry or Maxwell (unbiased), certainly by a small shop. I may be wrong though, my experience is limited. MR and Vray are my weapons of choice. I do own a FryRender license, but Ive yet to really take it by the horns. If you turn up any fresh info on Fry for animation, please post it here.
One thing is for sure, if youre using Fry you will need some power and DR.
If you’re going to do animations then Fry & Maxwell are out of the question, I used Maxwell to do several animations and the render times were outrageous. From what I've heard Fry is a little faster than Maxwell but it still can't compete with Vray or Mental Ray. When you move into the HD side of things then your render times are going to at least double if not quadruple and you can't afford to wait days for a frame to render. Vray and Mental Ray are very similar, each has it's strong points but if you're experiencing long render times in Vray it's because you haven't tweaked your settings appropriately and you should take another look at it.
Honestly, it sounds like you need to slow yourself down a bit. Develop your skills with Vray before you dive into HD animations, they are not to be taken casually.
