innerdream Posted December 11, 2008 Share Posted December 11, 2008 Just doing one of those Architectural Record type product shots. CC welcome. Link to comment Share on other sites More sharing options...
jophus14 Posted December 12, 2008 Share Posted December 12, 2008 Good start. I know it's a WIP but here are a few things that I noticed that you can either apply to your image or disregard 1. The white sofa looks plastic, it needs to look softer. Maybe adding pillow, a blanket draped over a side or an area rug will help. 2. The grout line of your tile floor should reach the wall. Either work wth your scaling or touch it up later in PS. 3. It will be hard to add a "good" sky to your image with such an abstract pane of glass. I would definitely add a background image. It'll get broken up by the bump on your glass so it will probably look really good too. Like I said before, you are off to a good start and it's completly up to you to create this scene. Keep posting. Link to comment Share on other sites More sharing options...
innerdream Posted December 12, 2008 Author Share Posted December 12, 2008 Thanks Joseph. I am trying to make the sofa look like leather, there is a bump map maybe I need to increase the value. The floor is an easy fix and I'm okay with the glass and background as is, but I can try an image back there. I'll keep at it. I'm not going to add pillows or a blanket because that's not the type of image I'm after. Thanks again! Link to comment Share on other sites More sharing options...
jophus14 Posted December 12, 2008 Share Posted December 12, 2008 Sounds good. What software are you using? Link to comment Share on other sites More sharing options...
