FMAGULLO1 Posted December 15, 2008 Share Posted December 15, 2008 (edited) Hello all Does anybody know how to create slopped reveals on a wall. I have tried it by placing a work plane on the face of the wall, and used a void form- void sweep combination, but when I press finish sweep, this message appears This Mass has no solid geometry for its Void Forms to cut. They must be deleted, or solid geometry added and cut. Please, let me know if you can help Thank you Francisco Edited December 16, 2008 by FMAGULLO1 didn't read right Link to comment Share on other sites More sharing options...
chiquito Posted December 15, 2008 Share Posted December 15, 2008 any image to see what you are looking for? Link to comment Share on other sites More sharing options...
FMAGULLO1 Posted December 16, 2008 Author Share Posted December 16, 2008 Hi Martin I enclosed a jpeg of the wall (it is just a basic wall). I have figured out out to do horizontal and vertical reveals. However, I seem to get no where with the sloped ones Let me know if you can help Thanks Francisco Link to comment Share on other sites More sharing options...
STRAT Posted December 16, 2008 Share Posted December 16, 2008 one thread will do please Link to comment Share on other sites More sharing options...
chiquito Posted December 16, 2008 Share Posted December 16, 2008 I would do as follows, If I understand correctlly what you want. Draw splines, tracing drawing of wall, edit spline, attach all of them into one, extrude. Convert to editable poly. vertex select, move vertices adjusting slope to choice. for the reveals, inset polygons, adjusting local, and either extrude in or out, depending on what you want. If bevel is needed, same procedure. Hope it helps. Share pict, Cheers martin Link to comment Share on other sites More sharing options...
FMAGULLO1 Posted December 16, 2008 Author Share Posted December 16, 2008 Hi Martin: Let me see if I can put it together Thank you very much Francisco Link to comment Share on other sites More sharing options...
FMAGULLO1 Posted December 17, 2008 Author Share Posted December 17, 2008 Hi Martin: I got it. I used an in place family for the wall, and used the void sweep for the reveal. Being new at this, my main problem was that I'm just starting to work with the massing, and was trying to add the sweeps to my in place family (wall), after finishing the massing (of the wall), and without first editing the mass. Anyway, thank you for your help I enclosed a jpeg of my practice wall Francisco Link to comment Share on other sites More sharing options...
chiquito Posted December 17, 2008 Share Posted December 17, 2008 for nex time, boolean and bump map? looks nice M. Link to comment Share on other sites More sharing options...
Tim Lusername Posted February 2, 2009 Share Posted February 2, 2009 HI I'm a noob but I've just been playing around with stuff like this and I've found that if you select the wall you want to modify and pick "edit profile" on the options bar then you can sketch any sort of opening shapes you want - hit finish sketch and you get the results. Any use or have I missed the point totally? Tim Link to comment Share on other sites More sharing options...
