Peter M. Gruhn Posted December 15, 2008 Share Posted December 15, 2008 OK, OK, I'll research it on my own if I have to, but maybe somebody knows the definitive answer off the top of their head. I'm all about real world size and real world uvw's and everything. Life is good. And then there's the noise map. It's a handy map. Use it for all sorts of things, but even back in the day I noticed that it rendered differently than it showed in the viewport. And now that I am all real worldy I notice that it doesn't have real world size (max 9). It does change size based on where and what kind of coordinates it is getting, so sometimes a "size" of 10 is good and other times a "size" of 0.01 is good. So anyway, how big is it really? I will spare you my many conjectures. - g Link to comment Share on other sites More sharing options...
Nic H Posted December 16, 2008 Share Posted December 16, 2008 arrggh i hate noise, why it doesnt display properly is beyond me maybe im missing something Link to comment Share on other sites More sharing options...
mattclinch Posted December 16, 2008 Share Posted December 16, 2008 short answer - not sure. long answer - i THINK, noise and all other procedural textures are not effected in scale by UV's. i've always taken the 'size' to be a real world unit, eg. scale of 1.0 when working in metres means the noise map is 1m in size. its only my rule of thumb though, and works 1 in every 4 or 5 times. i hate procedurals. make a 1k x 1k noise map of your own that tiles. far easier. Link to comment Share on other sites More sharing options...
Nic H Posted December 16, 2008 Share Posted December 16, 2008 yeah it took me quiet a while to realise that noise maps arent affected by uvw mods Link to comment Share on other sites More sharing options...
Gus_Rayvus Posted December 16, 2008 Share Posted December 16, 2008 You can change the noise map to explicit map channel. Then it will work with your UVW map. Link to comment Share on other sites More sharing options...
quizzy Posted December 16, 2008 Share Posted December 16, 2008 You can change the noise map to explicit map channel. Then it will work with your UVW map. and it will show correctly in the viewports as well Link to comment Share on other sites More sharing options...
Nic H Posted December 16, 2008 Share Posted December 16, 2008 news just in Link to comment Share on other sites More sharing options...
mattclinch Posted December 16, 2008 Share Posted December 16, 2008 ditto. you learn soemthing new every day... cheers fellas! Link to comment Share on other sites More sharing options...
quizzy Posted December 16, 2008 Share Posted December 16, 2008 this option was only known to dutch people.. ;-) until now.... Link to comment Share on other sites More sharing options...
danb4026 Posted December 19, 2008 Share Posted December 19, 2008 The noise map doesnt show up on the preview in the material editor once you change to explicit map channel. What's up with that? Link to comment Share on other sites More sharing options...
quizzy Posted December 19, 2008 Share Posted December 19, 2008 well prolly only works here in the netherlands OR you can try changing the size. Link to comment Share on other sites More sharing options...
quizzy Posted December 19, 2008 Share Posted December 19, 2008 LMAO ... ironical,.... the Uber mensch from the Nether lands... LMAOH Uber mensch = german Netherlands means belowlands but basically should be below sealevel cause almost half the country is below sealevel.. ;-) Link to comment Share on other sites More sharing options...
Derek Forreal Posted December 20, 2008 Share Posted December 20, 2008 You can change the noise map to explicit map channel. Then it will work with your UVW map. and it will show correctly in the viewports as well thanks for the great tip Guys. Link to comment Share on other sites More sharing options...
