markf Posted December 16, 2008 Share Posted December 16, 2008 I've added a second drive to one of my machines and installed a new Windows XP 64 bit. During the install I partitioned the drive. The install assigned the partitions "F" and "G". I have an external back up drive that uses those letters. I'd like to change these to "H" and "J" (don't think I want to use "I"). I read in windows help how to do it but there is a warning about causing files to not know the correct path if one changes a drive letter. So far I only have installed windows and nothing else. Is there any problem with me renaming these partitions? Link to comment Share on other sites More sharing options...
Macer Posted December 16, 2008 Share Posted December 16, 2008 (edited) Glad you got it installed. No, in your case (ie no other programs, etc) you can do no harm, as windows won't let you rename a drive if there are system files on it (the paths that the warning is refering to relate to ones that other installed programs would use). So, no problems if the partitions are blank, but if the system is using it there is nothing you can do (as far as I am aware). edit: lecameleon beat me to it as usual! (so you can use a software tool to change drive letters for system drives?) I have changed all of my drive letters (except for C: system drive) without having run into any problems. Edited December 16, 2008 by Macer Link to comment Share on other sites More sharing options...
markf Posted December 16, 2008 Author Share Posted December 16, 2008 Thanks to you both! Link to comment Share on other sites More sharing options...
