BrianKitts Posted December 17, 2008 Share Posted December 17, 2008 Has anyone else had an issue with placing a movie file in the diffuse channel for a material? We've done it in the past for animation projects to put content on television screens, but now in 3dsmax 2009 it's no longer working. A file created in 2008 opened in 2009 causes an error at rendertime that it can not read/write to the movie file, and a new material created in 2009 won't let you select a movie file for the diffuse texture. Link to comment Share on other sites More sharing options...
gfa2 Posted December 17, 2008 Share Posted December 17, 2008 I just tried it in max 2009 64bit (not max design) and it worked. I selected an avi...looks like mpg is also supported. Link to comment Share on other sites More sharing options...
amer abidi Posted December 17, 2008 Share Posted December 17, 2008 (edited) I just tried it in max 2009 64bit (not max design) and it worked. I selected an avi...looks like mpg is also supported. Weird. I also just tried it (32bit), and it doesn't work! won't allow it to be selected. very weird, Cause i've also done it so many time on previous versions of max. Will try again on 64 bit tomorrow and let you know. EDIT: Actually just thought of something, but dont have the means to try it out now. If you have previous versions of max (like 2008) where you are sure it works, try assigning the material in 2009 as an xref material. Like is said, just an idea, but might work. Edited December 17, 2008 by amer abidi Link to comment Share on other sites More sharing options...
BrianKitts Posted December 17, 2008 Author Share Posted December 17, 2008 interesting..... so the answer I got off of autodesk's forums is that 64bit max 2009 design doesn't have the codecs to run video, but run it as 32bit and you'll have no problem. that's just unfortunate. Link to comment Share on other sites More sharing options...
Nic H Posted December 18, 2008 Share Posted December 18, 2008 iv been opening the mov / avi's in fusion/aftereffects and saving out frame sequences of tgas to get around this rather annoying problem. just pick the first file and click sequence and max will make you a ifl to point to. Link to comment Share on other sites More sharing options...
quizzy Posted December 18, 2008 Share Posted December 18, 2008 .mov will never work now in 64bit cause apple didn't release a 64bit of quicktime... Link to comment Share on other sites More sharing options...
whori Posted December 19, 2008 Share Posted December 19, 2008 i am using max 2009 design 32bit. and it worked with mov file..dont know how about others Link to comment Share on other sites More sharing options...
