Koper Posted December 18, 2008 Share Posted December 18, 2008 So we have a bit of a small prob since we recently upgraded to vray SP2. We get different colors and contrast using the two different light map calculations methods. But we didn't get this probl in SP1. I linked two small videos (634kb) to show the difference. Animation pre-pass: http://www.nationalgraphix.com/ani/animationprepass.mpg Incremental add..: http://www.nationalgraphix.com/ani/incrementaladd.mpg and the settings If anyone know of a previous post or something, pls link it Thanx A Link to comment Share on other sites More sharing options...
Koper Posted December 18, 2008 Author Share Posted December 18, 2008 thats the way we render all animations, first calculate the lightmaps, then rendering using the lightmaps from file. the attached images only shows the setup for when we render from file. both works perfectly, just not together, and that meens when we render animated objects with the animation pre-pass method the color and contast changes significantly. Link to comment Share on other sites More sharing options...
Koper Posted December 18, 2008 Author Share Posted December 18, 2008 no, thats not the case, we get the same quality even if we split up sections of the animation -- Inc.Add then Ani.preP, then Inc.add, then .... and so on the different methods look the same respectavely to each other. and we render over a network. We calculate Inc.Add lightmaps only on one pc to avoid the flickering you are mentioning this problem in variation came when whe started using SP2 Link to comment Share on other sites More sharing options...
Koper Posted December 18, 2008 Author Share Posted December 18, 2008 another example of the difference the dark side is with animation pre-pass Link to comment Share on other sites More sharing options...
Koper Posted January 12, 2009 Author Share Posted January 12, 2009 bump... anyone? Link to comment Share on other sites More sharing options...
