Vray Material Help
mikedanchalski
Thanks for the replies!
I've already upped the gamma to 2.2 and got some favorable results (image 034 & 035)
I tried the exponential color mapping and got more improvement test 036
Are there any settings on the exponential mapping that could be tweaked? (exponential settings.jpg) I just changed the pull down from Reinhard
Mike
I think your exposure looks fine now. There are no rules to this, mainly because there are so many variables. There are a couple of procedures some people find helpful (search for LWF [linear work flow] and RWF). Its mostly a case of trial and error and practice.
You may find it helpful to be fairly controlled in your tests. Set up a simple test scene that renders quick and test material and light settings in that file.
Thanks again guys
I'm using a Vray sun and Vray sky in the environment. Sun pretty much has default settings. I'm also using a Vray Physical camera, also with default settings, though I started playing around with the white balance, setting it for daylight, (must have reset when I did the capture).
How do you disable the fstops? And what does vignetting do?
Mike
Edited by mikedanchalski
forgot attachments
