Ambient Occlusion...
omid
Usually Vray users do not use Ambient occlusion..Most of the time, there is no use for it.
You can refer to the tutorial about VrayDirt in the Vray help files
There is also some scripts around to generate the ambient occlusion pass,
http://plugins.angstraum.at/vrayao/
http://www.scriptspot.com/3ds-max/vray-ambient-occlusion
http://www.scriptspot.com/3ds-max/vray-autvel-passes
Hope it helps
i always make an 'ambient occlusion' pass. sometimes its useful, sometimes not.
multiply it over and adjust opacity to suit. use it as a mask to put some dirt on etc etc
make a VrayExtraTex render element and put a material on it with vray dirt as the diffuse. thats it. i wouldnt bother with scripts when its so easy to auto generate it.
my new fav ao trick (learned off a neoscape tut @ the-area) is to put a levels adjustment layer on top of your AO layer. The right slider adjusts your overall image up to it's white point, and beyond that it will cut back the depth of the AO, and your center slider adjusts the density (opacity) of the AO layer. it's pretty slick.
Thanx For Help But Why? In Mental It's Very Useful and make your Scene Reality.
I would disagree, you may be correct to say many don't use it, but you'll find it's popularity is growing. We use it on almost every production rendering.
you Right it's Useful but In Vray......Thanx For Help nicnic Edited by omid
