Question for GTX280 users
I just got my GTX280 and I would need some advises on how is the best way to configure it for Autocad and specially for Max to get the most of it:
Should I modify any settings at the Nvidia configuration panel and on each of the programs?
Do you advise me to use Direct3D or OpenGL?
DirectX9 or 10?
Thank you
Diego
DirectX9 or 10?
Thank you
Diego
Trywith this bench
http://rapidshare.com/files/3108339/bmark4.rar.html
unrar, and start max script, if it doesnt start first time, second it will, play with D3D/ OGL and post the results here, also write the MAX/Windows version (XPVista).
So, post the FPS first, to look it further, good luck.
Thanks Zdravko,
Some textures were not found.
Result as follows:
Processor: I7 920 @ 2.66GHZ - 6mb RAM
OS: Vista Home Premium 64-bit
MAX Version: 2009
Video Card: NVIDIA GeForce GTX 280
Display Type:
File Name | FPS
4viewports.MAX | 38.956
8direct.MAX | 174.978
8omni.MAX | 448.43
8spot.MAX | 459.77
blitting.MAX | 489.716
dualplanes.MAX | 548.446
geometry1.MAX | 547.445
geometry2.MAX | 366.3
multitex.MAX | 1.52749
rasterize.MAX | 323.729
textured1.MAX | 318.201
textured2.MAX | 96.5717
textured3.MAX | 189.394
transpar.MAX | 255.102
wireframe1.MAX | 5.07949
wireframe2.MAX | 5.05416
Comp High: 115.915
Comp Low: 107.888
I'm using D3D with Dx9, But..
Vista perfomance option -> visual effects is in: "let windows choose" which I think is closer or equal to best quality. I'll try without that and let you know.
For the rest I'm using D3D and NVIDIA's default settings, do you suggest me to change any parameter?
thank you
Nope, I'ver tried and it keeps around the same figures.
In the meantime I experimented your benchmark with a laptop whith both Vista and XP installed, and the results are disturbing. Xp undoubtely beats Vista and even in a slower machine It gave me 19 fps against 5 on the new one.
Did you have similar results when comparing Vista with XP?
Seems that I have to swith for XP?
Thank you
Max Version: 2009
Processor: T9300 @ 2.50 GHZ - 4 gb RAM
Video Card: NVIDIA Geforce 8600m GS
Display Type:
File Name | FPS
4viewports.MAX | 26.9833
8direct.MAX | 83.2293
8omni.MAX | 138.217
8spot.MAX | 132.45
blitting.MAX | 283.849
dualplanes.MAX | 291.935
geometry1.MAX | 118.624
geometry2.MAX | 83.1947
multitex.MAX | 1.34309
rasterize.MAX | 144.613
textured1.MAX | 171.821
textured2.MAX | 73.0727
textured3.MAX | 119.875
transpar.MAX | 90.4486
wireframe1.MAX | 3.07557
wireframe2.MAX | 3.02447
Comp High: 48.3096
Comp Low: 59.2566
_________________________________________________________
OS: XP Pro 64-bit
Max Version: 2009
Display Type:
File Name | FPS
4viewports.MAX | 59.2417
8direct.MAX | 118.554
8omni.MAX | 109.409
8spot.MAX | 103.199
blitting.MAX | 146.227
dualplanes.MAX | 143.019
geometry1.MAX | 87.26
geometry2.MAX | 67.6133
multitex.MAX | 1.34651
rasterize.MAX | 95.8038
textured1.MAX | 94.1147
textured2.MAX | 78.0488
textured3.MAX | 110.717
transpar.MAX | 91.9456
wireframe1.MAX | 18.9922
wireframe2.MAX | 18.3038
Comp High: 60.3464
Comp Low: 62.0861
