abicalho Posted September 15, 2003 Share Posted September 15, 2003 From Discreet Product Support: Technical Bulletin Sept 12, 2003 Attention All 3ds max® and Autodesk® VIZ Customers Microsoft Hotfix 824146 available for 3ds max and Autodesk VIZ which corrects the (.max) file corruption caused by recent Microsoft Windows Updates. (Updated September 2003) A previous Microsoft Hotfix (823980) which had been made available through Windows Update caused the corruption of 3ds max and Autodesk VIZ (.max) files.P> Whether you have updated to the previous security Hotfix 823980 or held back, you can now update to this new Microsoft Hotfix 824146. This will pick up both the security patch and protect the integrity of your product files. For further information about this new Hotfix, refer to Microsoft Product Support site at: http://www.microsoft.com/security/security_bulletins/ms03-039.asp WARNING – be sure to back-up any critical data on your system before installing the new MS Hotfix, or implementing any alternative work-arounds. To install it run Windows Update and install all Critical Updates. Note: This is needed for anyone running any version of Windows, regardless of service packs. For more information, check http://support.discreet.com or http://www.discreet.com/support/max Alexander [ October 09, 2003, 09:06 AM: Message edited by: Alexander Esppeschit Bicalho ] Link to comment Share on other sites More sharing options...
mike_sul Posted September 25, 2003 Share Posted September 25, 2003 For further information about this new Hotfix, refer to Microsoft Product Support site at: http://www.microsoft.com/security/security_bulletins/ms03-039.asp. the above link produces the following errrors .. We’re sorry, but there is no Microsoft.com Web page matching your entry. It is possible that you typed the address incorrectly, or that the page no longer exists. You may wish to try another entry or to use the links below, which we hope will help provide you with the information you need. pls advise Link to comment Share on other sites More sharing options...
abicalho Posted October 9, 2003 Author Share Posted October 9, 2003 Remove the period at the end of the link. I edited it in the original post already. The easiest solution for all these issues is simply to run Windows Update and install all critical hotfixes that are available. Alexander Link to comment Share on other sites More sharing options...
