steve Posted February 22, 2004 Share Posted February 22, 2004 Hello everybody I am a new user of vray adv. and after doing a small test rendering, I set few questions I am sure many of u have answers to them. 1- Can we use all kinds of light with vray or simply vraylight? what about raytraced shadows? 2 - Do you simulate real life light design placing a light where specified or simply simulate light in general ? How many lights are generally used in average ? 3- Does vray fits for exterior lighting using only on light for the sun ? again what about raytrace shadows ? 4- Does vray work with standard material or all should be transformed into vray material? 5- How do you create transparent glass ?The old max way of simply changing opacity is not available. 6- what are the main parameters to change for a good light setup ? ( is it irr. map for 1st and photon for 2nd ?. I can't get the fast rendering times i see on your renderings . 7 - Should we save and re-use irr map and photon map in animations ? 8- Any clue about these white dots apperaring in my attached test rendering ? 9 - Can we render a low resolution image and re-use the saved lighting for a higher rendering? 10 - Can we create non regular shaped lighting with vray? an S neon shape for example. I will really appreciate detailed answers from the vray experts as I am sure these feed back will be a great help for many new users Salut to all Link to comment Share on other sites More sharing options...
PP Posted April 5, 2004 Share Posted April 5, 2004 HI, I´ll answer some questions 1- you can use all kind of light, also with shadows (but v-ray shadows are faster) 2-You can use just one light to simulate real life light 3-Yes, is very useful simulate for exterior lighting using only one light for the sun , and agian, use v-ray shadows 4-vray does work with standard material, but it doesn´t work so well with raytraced 5-You have to adjust the refraction a little bit to middle gray , it becomes tranparent, and if you want to fully transparent the coluar have to be white. 6- Use it irr. map for 1st and direct for 2nd (see osmosis tutorial, http://www.osmosis.com.au/info/tutorials.htm) 7- I don´t have many expererience on animations, I think you should 8- Maybe you are using a raytraced material, or maybe you didn´t apply a UVW modifier to all your geometry, or.. maybe you used the camera correction modifier of max 6 9-I don´t have many expererience on that subject 10-es you have to use an output map on the self ilumination chanel of your material Hope this helps! Link to comment Share on other sites More sharing options...
dleon Posted April 19, 2004 Share Posted April 19, 2004 Evermotion.org has a collection 52 free videos demostraiting most of VRay's unique and distinct approaches to doing things. They are soundless .avi files. No voice info. This doesn't really hurt though, as the demo is very watchable and followable if you concentrate. Surprisingly, I would rate these videos as one of the finest learning experiances I have ever had. Before I did those tutorials, I could not do photorealistic work. Now that's just about all I am doing. It's surprisingly easy when you know how. Dave Link to comment Share on other sites More sharing options...
Christopher Nichols Posted April 20, 2004 Share Posted April 20, 2004 8 - the white dots are usually the sign of a licensing issue, or the fact that you may be using a pirate version. If you have the first one, contact the Vray people, if you have the second one, keep in mind that this forum does not generally "help" unlicensed users. But I may be very wrong... since I can't see the image you tried to attach. Link to comment Share on other sites More sharing options...
steve Posted April 27, 2004 Author Share Posted April 27, 2004 Adding uvw mapping to those objects did solve the white spots problem.Thanks for the great tip and for all your replies guys. I am going to check evermotion now Link to comment Share on other sites More sharing options...
Richard McCarthy Posted June 11, 2004 Share Posted June 11, 2004 8 - the white dots are usually the sign of a licensing issue, or the fact that you may be using a pirate version. If you have the first one, contact the Vray people, if you have the second one, keep in mind that this forum does not generally "help" unlicensed users. But I may be very wrong... since I can't see the image you tried to attach. I think those white dot he is refering to is the Photon... not enough of it. Link to comment Share on other sites More sharing options...
Craig Ramsay Posted September 15, 2004 Share Posted September 15, 2004 are these 52 videos free am i asking for too much Yes they are free and very good! Link to comment Share on other sites More sharing options...
Iain Denby Posted September 15, 2004 Share Posted September 15, 2004 Yes they are free and very good! Where are they, I can't find them? Link to comment Share on other sites More sharing options...
Craig Ramsay Posted September 15, 2004 Share Posted September 15, 2004 Where are they, I can't find them? They are here: http://www.evermotion.org/?unfold=tutorials&unfold_tutorials=4#1.4 Link to comment Share on other sites More sharing options...
mervin_lim23 Posted September 14, 2008 Share Posted September 14, 2008 :)hello everyone!! Im Arch mervin and im glad to be part of this community. im just a newby as far as vray rendering is concerned and im hoping to hear some tips and trick from all of you guys here at cgarchitects. and i would also like to thank cgarchitect for your warm welcome. thanks Link to comment Share on other sites More sharing options...
myusuf Posted March 21, 2009 Share Posted March 21, 2009 I am not finding them. Is it specifically mentioned that 52 video tutorials...Please let me know... Link to comment Share on other sites More sharing options...
BrianKitts Posted March 21, 2009 Share Posted March 21, 2009 I am not finding them. Is it specifically mentioned that 52 video tutorials...Please let me know... That is because this thread is 4 years old and the videos are no longer available. Which is good considering they would be misleading such that vray has changed in for years and the old videos would not matchup to the latest build. Link to comment Share on other sites More sharing options...
