Aaron Posted January 5, 2004 Share Posted January 5, 2004 I am trying to model a wall surface in max 5 and I was looking over my progress and found that where points should align in a corner, they don't. The wall is cut up for detail purposes (ie, window openings, doorways) and when I try to manually set the location of the corner points, the application seems to ignore my location entry and places the point to the original position. included is a image of what my corner looks like. This is a top view that is zoomed in as far as it will go. Thankfully, the wall seems to look fine when viewed from a camera for rendering. But why are my wall corners becoming distorted and why can't I set them to a set location so that they all align? Please note, that I can move the points to another location but I cannot seem to set them to a position where they all align. Incidently, the surfaces are one sided and were created using the edit poly modifier. I was using the connect edges and extrude edges to create all the geometry. http://www.cgarchitect.com/forum/filepush.asp?file=pic_1.jpg Thanks for any help. Aaron Link to comment Share on other sites More sharing options...
Gander0 Posted January 7, 2004 Share Posted January 7, 2004 Have you tryed scaling the whole thing up maybe you've built your model to small....just a thought. Here are some posts on snap setting: http://www.cgarchitect.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=11;t=000010 Gander Link to comment Share on other sites More sharing options...
CEJ Posted January 7, 2004 Share Posted January 7, 2004 i think you might have axis constraints on, turn it of and you can move the vertex wherever you wish. Link to comment Share on other sites More sharing options...
Aaron Posted January 7, 2004 Author Share Posted January 7, 2004 Thanks for your help! CEJ, the link to a previous post about snaps is very helpful. Snaps are probably the root of my problem and I'm going to follow those suggestions in the future. The problem I am having still puzzles me though because the vertices still return to the original unaligned position even after I set each one manually to a common point. The thing that makes the unaligned vertices ok is that they vary a maximum of 1/100th of an inch. Not noticable in renderings... Thanks again for the help - Aaron Link to comment Share on other sites More sharing options...
smoke3dstudio Posted January 7, 2004 Share Posted January 7, 2004 From the picture, I am not too sure to tell. Possible to post another perspective view? or can send me the model to examine? Have you tried using view alignment or make planar? Link to comment Share on other sites More sharing options...
Aaron Posted January 7, 2004 Author Share Posted January 7, 2004 smoke3dstudio, I uploaded the portion of the wall I have been dealing with. The entire model has similar problems. The file was saved in MAX 5. I colored the portion of the wall I have been examining, red. I also placed a camera that shows the problem. If you cannot read MAX 5 file, I also exported it to 3ds but the corner is not colored and there is no camera. Incidently, I tried the make planar and align to view and still had the problem but it wasn't as bad. links to files: http://web.njit.edu/~arf3/points.max http://web.njit.edu/~arf3/points.3DS thanks Aaron Link to comment Share on other sites More sharing options...
smoke3dstudio Posted January 7, 2004 Share Posted January 7, 2004 Aaron, It's the camera problem. Your camera setting was odd and made me confused at the begining. I think you could not move the vertexes properly in this camera view. So, try not to move anythings in this kind of camera view. I have also adjusted the vertices alignment for you (by selecting all vertices and use VIEW ALIGN to left view) already. Just chk if it 's correct or not. http://www.smoke3dstudio.com/points.zip [ January 07, 2004, 10:49 PM: Message edited by: smoke3dstudio ] Link to comment Share on other sites More sharing options...
Aaron Posted January 7, 2004 Author Share Posted January 7, 2004 You solved the problem! Thanks for your help. Link to comment Share on other sites More sharing options...
