Interactive Modelling for 3DS Max
dande
Hi
I have a client that first required some rendered images of a development. As per usual I built the model and used MR Materials and Sun/Sky etc.
He now would like an interactive animation so that his clients can move around the development. But the problem is he wants the quality of the interactive animation to be as good as the rendered images.
I have looked at quest3D. But this only allows you to use standard materials also it does really render, so you don't get lighting effects on materials and the overall quality of the Quest 3D animations look pretty poor. Also I would have to re-texture the whole model with standard materials.
Does anybody have any experience of any interactive animation packages that give good quality animations.
One thought I had was if I rendered all the building to texture that this may get over the problem with having to use standard materials. This is just a thought as I have never used render to texture before.
You could make a series of quicktime panoramas. With the right authoring tool yoou can create hotspots and link animations. So the client can interact in areas (360 pan) and move to other areas through hotspots.
That way you are in reality just moving through pre-rendered stills
