sdds Posted January 3, 2009 Share Posted January 3, 2009 anyone know of a good script to shutdown or better put a computer to sleep when the cpu gets to hot? I am using speedfan, I need more cooling cpu is hitting 67 under load.. Link to comment Share on other sites More sharing options...
Superfinicky Posted January 4, 2009 Share Posted January 4, 2009 I'm running a system using a Pentium D 3.2ghz CPU. Under normal load with water cooling my processor is at about 50 degrees [Celsius]. Under heavy loading I reach up to 97 degrees. I'm far from an expert on the matter, but I have been using this PC for about 6 months now and have not experienced any negative side effects. I have suffered one blue screen in that time frame with no noticeable loss in performance or system stability. This leads me to believe that perhaps my CPU temperature monitor indicates faulty temperature readings for the CPU. My system never tops 32 degrees under any circumstances, although my GPU can hit 100 degrees. I've been using SpeedFan 4.35 to monitor temperatures. Link to comment Share on other sites More sharing options...
