danb4026 Posted January 5, 2009 Share Posted January 5, 2009 I mistakenly posted a previous render of this room on "finished work" prior to it being finished. It is still a work in progress. I am not sure where else to go with this image to make it more interesting. Any advice, criticisms welcome. Link to comment Share on other sites More sharing options...
bearsign Posted January 5, 2009 Share Posted January 5, 2009 Hi, at first I must say that it seems finished even this way On the other hand -just for advice of course- I can say that maybe changing the cam position (may some up and/or just some right/left) can give a different feeling. I can't really figure it in my mind, but worth trying. I think sun light would be dominant, inner lighting would be ressesive and a little contrast would give some expression to scene. Again changing the sun position and letting it to fall on the bed would give a better feeling. Maybe a night version can be added too. As I said, just ideas... Nice architectural design & visualisation. Link to comment Share on other sites More sharing options...
danb4026 Posted January 5, 2009 Author Share Posted January 5, 2009 Thanks for your comments. I will play with the sunlight and dim the interior lighting to see what it achieves. Link to comment Share on other sites More sharing options...
danb4026 Posted January 6, 2009 Author Share Posted January 6, 2009 Here are a couple of updates. In the first I tried to make the room feel as if the sun was the major light source. The other image has a warmer feel, but not necessarily correct. C&C? Link to comment Share on other sites More sharing options...
bearsign Posted January 7, 2009 Share Posted January 7, 2009 First one is my choice The second one has no problem except for the background doesn't fit the lighting maybe with a darker background... Nice updates, congratulations Link to comment Share on other sites More sharing options...
neil poppleton Posted January 10, 2009 Share Posted January 10, 2009 2nd one for me. I think the bricks are mapped too small. Maybe get the brick joints more displaced or bump map and get the spot lights picking up the joint detail Link to comment Share on other sites More sharing options...
Horhe Posted January 11, 2009 Share Posted January 11, 2009 Thats one wonky window Id go for the first one, the much brighter one, seems more cosy and inviting. The lattice on the window could be a bit thicker, right now it seems extra thin, one shove and itll fall apart. Link to comment Share on other sites More sharing options...
