mcs84 Posted January 7, 2009 Share Posted January 7, 2009 Good Day to All, I have just started to learn vray for use in my interior renderings. Currently I am facing a problem of my renderings being patchy. The following render was done in 1200 x 900 res. I am unable to post any image links as this is my 1st post (anyway around this?). My current settings are as follows: 1) Adaptive DMC (min subdivs = 1, max subdivs = 4), Catmull-Rom DMC Sampler: Adaptive amount = 0.85, Noise Threshold = 0.005, Min Samples = 8, Global Subdivs Multiplier = 1.0 2) Indirect Illumination (GI): Primary Bounces = 1.0 (Irradiance Map), Secondary Bounces = 0.85 (Light Cache) 3) Irradiance Map: Preset High (min rate = -3, max rate = 0), HSph Subdivs = 30, Interp. Samples = 20, Interpolation Type: Least Squares Fit, Sample lookup: Density Based (Best) 4) Light Cache: Subdivs = 1000, Sample Size = 0.02, Scale = Screen, No. of Passes = 8 5) Caustics: Multiplier = 1.2, Search Dist = 5.0mm, Max Photons = 60, Max Density = 0.0mm I left 2 Sides of the walls to allow light to pass through as I wanted to save time created the whole of the floorplan. I was wondering if it has to do with using the default global lighting. Should I have created an enclosed space and used a vray sunlight instead? Looking forward to any replies. Thank you very much~! Link to comment Share on other sites More sharing options...
STRAT Posted January 7, 2009 Share Posted January 7, 2009 I am unable to post any image links as this is my 1st post (anyway around this?). just type the www address into your post here. we'll copy and paste. (make the hemi samps higher) Link to comment Share on other sites More sharing options...
mcs84 Posted January 7, 2009 Author Share Posted January 7, 2009 img368.imageshack.us/img368/6531/diningeditedws0.jpg Link to comment Share on other sites More sharing options...
STRAT Posted January 7, 2009 Share Posted January 7, 2009 i see it i use the c4d vray. to smooth out the blotches i'd up the hemi samples considerably, then i might also up the inters a few too Link to comment Share on other sites More sharing options...
mcs84 Posted January 7, 2009 Author Share Posted January 7, 2009 Thanks alot. I managed to solve the problem by increasing the DMC Sampler and global subdivs multiplier to 16 Link to comment Share on other sites More sharing options...
STRAT Posted January 7, 2009 Share Posted January 7, 2009 upping the global subdivs multiplier isn't the correct way to do it. Link to comment Share on other sites More sharing options...
mcs84 Posted January 7, 2009 Author Share Posted January 7, 2009 I was following the vray interior tutorial at the website vray.us and it solved the blotchy patches. Is there a better solution you would recommend? They did mentioned this in the tutorial with regards to the Hsph subdivs and global subdivs: "The increased Global subdivs multiplier affects the irradiance map too, so if we render now with GI, it will be too slow. Set the Hemispheric subdivs for the irradiance map to 8.0." Any comments will be greatly appreciated Link to comment Share on other sites More sharing options...
Nic H Posted January 7, 2009 Share Posted January 7, 2009 thats a weird way to clean up gi splotches. try something like 50/30 and -6,-1. Link to comment Share on other sites More sharing options...
mcs84 Posted January 7, 2009 Author Share Posted January 7, 2009 Thanks alot nicnic, that really cleared up the splotches too and it renders much faster~! Thank you very much~! Still wondering why the tutorial taught that method. And its the official vray web too~! Link to comment Share on other sites More sharing options...
STRAT Posted January 7, 2009 Share Posted January 7, 2009 it's might be explaining something different. you shouldn't clean splotches up by globally increasing samples. Nic's solution is what i told you in the beginning Link to comment Share on other sites More sharing options...
Nic H Posted January 7, 2009 Share Posted January 7, 2009 vray.us is a spam site as far as i know, not offficial. check out chaosgroup forum. also take a look at Brian Smiths tutorials, they are an excellent foundation for troubleshooting stuff like this Link to comment Share on other sites More sharing options...
mcs84 Posted January 8, 2009 Author Share Posted January 8, 2009 Thank you very much to both nicnic and strat Will look more into the tutorials. Link to comment Share on other sites More sharing options...
gfriedman Posted January 15, 2009 Share Posted January 15, 2009 thats a weird way to clean up gi splotches. try something like 50/30 and -6,-1. what are those values for? sorry I'm kind of a noob. I'm having the patchy render problem Link to comment Share on other sites More sharing options...
caicedor Posted January 30, 2009 Share Posted January 30, 2009 Hi, I'm new to the forum and new using vray, but I think those values are for Hsph subdivs, interpol. Samples, min rate and max rate of irradiance map. Please somebody correct me if I'm wrong!! Link to comment Share on other sites More sharing options...
aaronrumple Posted January 30, 2009 Share Posted January 30, 2009 Hi, I'm new to the forum and new using vray, but I think those values are for Hsph subdivs, interpol. Samples, min rate and max rate of irradiance map. Please somebody correct me if I'm wrong!! That's correct. I usually start with a medium IR setting and then adusts the min/max rate per the image size. I typically use -5,-3 for a 1900px wide image. I also stay with the stock 50/20 for the Hsph and interpol. Those could probably be adjusted for more speed. Also images without enough light or poor exposure settings will tend to be more splotchy in my experiance. Link to comment Share on other sites More sharing options...
