fadi3d Posted January 7, 2009 Share Posted January 7, 2009 hello everybody, this problem is driving me crazy they uppgraded the pcs at the office to win 64 and vray 64 (Max 2009) the problem is the sun doesn't get through the glass anymore, or if it does it is very patchy like spots and dots. does vray 64 settings differ or the material settings Pls help thank u in advance Link to comment Share on other sites More sharing options...
BrianKitts Posted January 7, 2009 Share Posted January 7, 2009 there are no differences between the two architectures. Most likely you accidentally changed some of the settings on your glass. Is the "affect shadows" option enabled? Link to comment Share on other sites More sharing options...
Joseph Petrino Posted January 7, 2009 Share Posted January 7, 2009 Sounds like you upgraded vray as well as going from 32 bit to 64 bit. Check out the status "Legacy sun/sky/camera models" on the "Global" tab. The sun acts differently. Link to comment Share on other sites More sharing options...
fadi3d Posted January 8, 2009 Author Share Posted January 8, 2009 hello guys, dear friends thank u both for being so kind and try to help. Joseph turning on the legacy sun only made the sun much weaker (darker scene) Dear Brian affect shadows did solve the problem but i double checked and my Glass material in previous projects did not have affect shadow and worked fine (with max 2009 and vray 32 and vista 32) so pls could u explain why? and if this is the right method ? for i once read that Vray gives fake results this way. thank u very much Link to comment Share on other sites More sharing options...
BrianKitts Posted January 8, 2009 Share Posted January 8, 2009 I really don't know why it didn't work for you in 32bit. I have both 32 and 64bit Max/Vray on my machine and in testing with both I can't recreate your situation. As for being inaccurate, I would say it's the opposite. Selecting the option is more accurate since it allows your glass to transmit the color either from it's refraction swatch or fog setting. Link to comment Share on other sites More sharing options...
fadi3d Posted January 9, 2009 Author Share Posted January 9, 2009 Dear Brian, First of all Thank u for ur Help i much appreciate it.in the end i am glad it solved my problem but it just seems weird that what worked in vray 32 fine is not the case in Vray 64 as for the Affect shadow issue i will look into it more trying to find the tut where it said we should do without it.any further discoveries i'll report back. Cheers mate Link to comment Share on other sites More sharing options...
