Crazy Homeless Guy Posted May 28, 2003 Share Posted May 28, 2003 I have a quick question. I am trying to render my first project in Max. Everything is going slow, but ok so far. The problem I am having is when I try to render a radiosity solution. The wall on the left is made up of three pieces. The bottom is obviously a different material. The top two pieces are the same surface style. When I render without radiosity, the wall renders as expected. However, when I turn on radiosity, the upper portion of the wall looks like to different pieces (which it is). The same thing is happening on the back wall and ceiling tiles. What setting do I need to be tweaking to fix this. Without radiosity turned on.... With radiosity turned on... Link to comment Share on other sites More sharing options...
quizzy Posted May 28, 2003 Share Posted May 28, 2003 Hey travis, You have to model phisically correct, there are a lot of threads in here you could use... try the search option... Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted June 3, 2003 Author Share Posted June 3, 2003 for anyone who comes across this post in the future... http://www.cgarchitect.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=6;t=000095 Link to comment Share on other sites More sharing options...
