shikodesign2000 Posted January 14, 2009 Share Posted January 14, 2009 Hi, When I import 3d models containing curves from autocad 2008 to 3dmax 2009, the curves don't come properly, they are jagged and there's no any smoothness..,I tried traditional ways in autocad and 3dmax but no solution. In autocad I made higher (arch. and segments smoothness, segment in a polyline curve and rendered object smoothness). In max I tried to change the smoothness settings in the import dwg dialog when i import the 3d object from autocad. Anyone has any suggestion?? Link to comment Share on other sites More sharing options...
bev.lynn Posted January 14, 2009 Share Posted January 14, 2009 Sherif, In AutoCAD try setting Facetres to 10 and Isolines to 50 and see if this helps. Link to comment Share on other sites More sharing options...
shikodesign2000 Posted January 15, 2009 Author Share Posted January 15, 2009 Ok, but can you tell me where I can find these 2 options? Link to comment Share on other sites More sharing options...
bev.lynn Posted January 16, 2009 Share Posted January 16, 2009 In Autocad at the command prompt type Facetres and press enter. In response to the prompt, type 10, then press enter. Do the same for Isolines. The ISOLINES system variable controls the number of tessellation lines used to visualize curved portions of the wireframe. The FACETRES system variable adjusts the smoothness of shaded and hidden-line objects. After you do this, try importing you model into max again using the Legacy AutoCAD file type. I hope this helps! Link to comment Share on other sites More sharing options...
shikodesign2000 Posted January 17, 2009 Author Share Posted January 17, 2009 Thanks Beverly, but unfortunately, this didn't work also.. Link to comment Share on other sites More sharing options...
bev.lynn Posted January 17, 2009 Share Posted January 17, 2009 Because the model appears properly in AutoCAD and you enabled the smoothing angle on import, the only other thing that I can think of: Is the model located at 0,0,0 in AutoCAD? If anyone else can chime in here, I'm curious as to what else could cause this problem. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted January 17, 2009 Share Posted January 17, 2009 If you use the standard dwg import it will always approximate the curves to a number of steps that you can define in the import dialogue box. If you want your curves to come in properly as beziers then use the Legacy Autocad import option. You don't get the same choice over picking layers etc. it just all comes in, but the upside is your curves will be perfect! Link to comment Share on other sites More sharing options...
shikodesign2000 Posted January 18, 2009 Author Share Posted January 18, 2009 I use the import dwg command, and i made all (curve steps) and (smooth angle) and (maximum surface deviation) as high as possible....but the same problem exists. Please if anyone can help, this will be great.. I think that the problem is autocad cad has some problems with max2009!! I don't know.. Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted January 18, 2009 Share Posted January 18, 2009 try making surface deviation as low as possible. Link to comment Share on other sites More sharing options...
WAcky Posted January 19, 2009 Share Posted January 19, 2009 read stef.thomas's post again. This is correct. It has been covered by Brian Smith time and time again. Try here. http://www.cgarchitect.com/upclose/VI/Week1/CGA_VI_Site-PartI.pdf Bottom of p12/ top of p13. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted January 19, 2009 Share Posted January 19, 2009 read stef.thomas's post again. This is correct. It has been covered by Brian Smith time and time again. Try here. http://www.cgarchitect.com/upclose/VI/Week1/CGA_VI_Site-PartI.pdf Bottom of p12/ top of p13. Glad someone noticed, I didn't see the point in repeating myself. Link to comment Share on other sites More sharing options...
mckichan Posted March 12, 2009 Share Posted March 12, 2009 I am also having this problem, importing a curve from AutoCad LT 2009 to Max 2009... I have followed exactly Brian Smiths directions (have his book) and although the curves are better they still are not perfect. The first image is from autocad, and the second is from Max using the legacy import option. The curves should follow each other but dont, and the radius' are all off... Very frustrating while I am trying to extrude window frames! Link to comment Share on other sites More sharing options...
WAcky Posted March 12, 2009 Share Posted March 12, 2009 can you change the interpolation of the editable spline in max to adaptive? It may smooth the curves and correct them... Link to comment Share on other sites More sharing options...
mckichan Posted March 12, 2009 Share Posted March 12, 2009 Yes I tried that, and it fixed it to a degree, but still off. It almost seems to me that max is calculating the radius of the spline all off from cad. Some of the radius' have no verticies and some have one. I am new to this workflow, and am guessing the solution is to just draw the splines in Max and extrude there, but I would need a lot of practice with that! Link to comment Share on other sites More sharing options...
erickdt Posted March 12, 2009 Share Posted March 12, 2009 Hi, When I import 3d models containing curves from autocad 2008 to 3dmax 2009, the curves don't come properly, they are jagged and there's no any smoothness..,I tried traditional ways in autocad and 3dmax but no solution. In autocad I made higher (arch. and segments smoothness, segment in a polyline curve and rendered object smoothness). In max I tried to change the smoothness settings in the import dwg dialog when i import the 3d object from autocad. Anyone has any suggestion?? The problem you're experiencing is due to the import settings in MAX. When you import your AutoCAD file make sure to have your "curve steps" set to around 100 and your "maximum deviation for 3D solids" set to around .005. That should solve your problem! E Link to comment Share on other sites More sharing options...
mckichan Posted March 12, 2009 Share Posted March 12, 2009 Sorry, still no luck! Link to comment Share on other sites More sharing options...
