Lighting
Jonny English
I don't think that is possible unless you delete again all your lights. As long as your lights are in the scene whether on or off it will disable the max default lighting.
However, i'm not sure if your concern can be done using maxscript.
Cheers
Hi,
There is an option under the 'Views' pull-down menu that says "Add default lights to scene".
First you need to go to the viewport configuration and turn on the "Default Lighting" checkbox, and select one or two lights. The 'Add Default...' option is greyed-out until then.
Then select the 'Views->Add Default...' menu option, then tell it what you want added: Key and/or Fill lights.
[ October 01, 2003, 09:29 PM: Message edited by: Jennifer ]
Thanks all,
I think Jim got the idea of what I was trying to do - i.e. have a simple lighting rig to do some quick test renders - I will try that Jim, thanks.
The suggestion about adding deault lighting from view would not work for my needs as I believe it adds physical lights to the scene.
Thanks again,
Jonny English.
