jameson101 Posted January 15, 2009 Share Posted January 15, 2009 Here are 3 renders I have recently done. I modeled this 2 years ago and now the client wants us to continue(long Story). No post work has been done. There is no Vray Displacement and would like to keep the render as quick as possible bacuase I am doing a long animation and don't have much time. I am using 3d Studio max, Vray and onyx trees. Any help/comments on improving the renders would be greatly appreciated. All materials are to the architects specification, I know it looks like a prison. Link to comment Share on other sites More sharing options...
WrxSTiJoe Posted January 15, 2009 Share Posted January 15, 2009 Bricks are HUGE!! Link to comment Share on other sites More sharing options...
shaneis Posted January 15, 2009 Share Posted January 15, 2009 ...would like to keep the render as quick as possible bacuase I am doing a long animation and don't have much time... Exteriors: - match the brick texture of the planter boxes with the rest of the brick work, - lose the reflections on the garage door (paint them in if you really need them), - the road texture looks procedural, yes? Maybe darken it just a bit. If you have a reasonable res image, use that instead. - Paint stripes look 3D rather than paint. (see above) Interior: - All looks OK for a rush job (no offence intended), but I think you'd be better off rendering a separate reflection pass (apply blur in post, render sharp refl. and adjust softness as needed in your comp software). - Get rid of the reflections on the ceiling material. Link to comment Share on other sites More sharing options...
jameson101 Posted January 19, 2009 Author Share Posted January 19, 2009 Here are a couple updates, only of the exterior The brick is correct now, thanks Did a little post work but nothing special. Please any crits and comments welcome, any way to make it better would be helpful. Thank you Link to comment Share on other sites More sharing options...
neil poppleton Posted January 19, 2009 Share Posted January 19, 2009 The bricks are still too big. Link to comment Share on other sites More sharing options...
Nic H Posted January 19, 2009 Share Posted January 19, 2009 bricks too big Link to comment Share on other sites More sharing options...
jameson101 Posted January 20, 2009 Author Share Posted January 20, 2009 The bricks are 20cm by 10cm. What is the size of a normal brick? Link to comment Share on other sites More sharing options...
neil poppleton Posted January 20, 2009 Share Posted January 20, 2009 A brick uk metric is 215mm x 65mm with a 10mm joint so they map 225 x 75mm including a joint Link to comment Share on other sites More sharing options...
skala67 Posted January 27, 2009 Share Posted January 27, 2009 I think the car parked next to the building may be too small also. Link to comment Share on other sites More sharing options...
Tommy L Posted January 27, 2009 Share Posted January 27, 2009 here did you get the model of the Audi R8? Link to comment Share on other sites More sharing options...
Fermino Posted February 3, 2009 Share Posted February 3, 2009 here did you get the model of the Audi R8? X2 Is it a free model out there? Link to comment Share on other sites More sharing options...
ankit4d Posted February 3, 2009 Share Posted February 3, 2009 The tree bark color looks washed out... Link to comment Share on other sites More sharing options...
