upshot Posted January 16, 2009 Share Posted January 16, 2009 Okay.. I'm an admitted finaltoon addict. Lately I've been trying to get cebas's updated plug-in to work with vray (1.5/max2009) with little luck... The only way I've found to get it to work is to convert the camera to a perspective view and mess with logarithmic exposure control or the vray color mapping or render a second scanline pass and compost it.... Anyone else have a better approach? TIA Link to comment Share on other sites More sharing options...
Thablanch Posted January 19, 2009 Share Posted January 19, 2009 I do not know about max 2009, but for sure, a while ago, Vray 1.47 and Max 9 was working quite fine. It was a standard production pipeline for a catalog where I was once working. The setup was simple, vray as renderer, and final toon as effect.. without any problems. So mabee FinalToon changed in the last years, cause I think vray way of woirking renmained the same since 1.45 and up. ** what about the Vray toon plugin, do you really need the lines to be vectorized.... Vray toon is less versatile than FinalToon, but still quite cool Link to comment Share on other sites More sharing options...
upshot Posted January 22, 2009 Author Share Posted January 22, 2009 I figured it out... you have to add a clipping plane to your vray camera! then it works fine. I'm happy as a clam. ;-) Link to comment Share on other sites More sharing options...
gfriedman Posted December 14, 2009 Share Posted December 14, 2009 I'm having similar trouble - so clipping plane and that's all? I have been going mad trying every possible option. if you have any other tips on how to get the two to behave, I would totally appreciate it...thanks Link to comment Share on other sites More sharing options...
