Problem with units
Ivan_m
Hi
I have a question regarding the drawing units in AutoCAD. I was given a drawing in which the drawing units were architectural and in the field "Insertion scale" it says "Inches". The floorplans and the facades are both in centimeters and when I imported the situation (which is in architectural units as I said previously) they don't match each other. How can I convert arch. units in centimeters? :(
the only way to convert drawing units (arch to decimal centimeters) in autocad is to scale the drawing by the conversion factor.
in this case, one architectural unit (inch) is equal to 2.54 centimeters, so you need to scale the entire drawing by this number.
make sure all your layers are on/thawed/unlocked and also change your drawing units (UN) to decimal and the 'insertion scale' to centimeters (although that is likely unnecessary for what you're doing)
hope this makes sense
Thanks a lot. That worked. :)
I've devided 1 with 2.54 and scaled all down with factor 0.3937.
sounds like you've got it, but the conversion factor of .3937 is for converting centimeters to inches, not inches to centimeters.
