leoviale Posted January 20, 2009 Share Posted January 20, 2009 (edited) Hi guys, is there a way to map this? The walls i've done it with a simple spherical mapping, no capping, and i repeated titling 40 times, but i need somehow a way to apply the map in a sort of "ring" mapping, to apply it to the floor. It's there a way to do this? Edited January 20, 2009 by leoviale Link to comment Share on other sites More sharing options...
lecameleon Posted January 20, 2009 Share Posted January 20, 2009 (edited) Hi, I guess you meant cylindrical mapping... in any case, when you are dealing with complex surfaces, you will have to use something better than the preset mapping methods available. You will probably have to look into unwrapping UVW.. on a very simple level you can add the unwrap UVW modifier on top of your steps poly, then in the unwrap modifier choose face level editing and select contiguous polys (ring or loop) and then choose quick planar map (or cylindrical) and play around with those settings if you are disinclined to unwrap it in the editor.. You can select each of the polys separately and add a quick planar map.. While this is not the only solution, this may be the simplest.. try it.. Edited January 20, 2009 by lecameleon Link to comment Share on other sites More sharing options...
Nic H Posted January 20, 2009 Share Posted January 20, 2009 remodel with a loft get a spline from the poly edges by selecting a loop then loft the profile around that spline. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted January 20, 2009 Share Posted January 20, 2009 remodel with a loft get a spline from the poly edges by selecting a loop then loft the profile around that spline. I second that. Basically with complex geometry you want to avoid applying a generic uvw map and have the geometry generate its own implicit uvw mapping coordinates. As Nicnic said create a cross section of your shape then loft or lathe it around in a circle. Make sure you tick the box which says 'generate mapping coordinates' on your modifier rollout. I also prefer to tick the 'real world coordinates' box and set the dimensions in the material editor. Link to comment Share on other sites More sharing options...
leoviale Posted January 20, 2009 Author Share Posted January 20, 2009 Well, that solves the problem. Now, is there an issue here, if i convert this loft to a editable poly, as I need to continue modeling, for example, if i want to use something as the insert tool and extrude, the map setting get screwed, even if i check preserve UV, I think there may be way to solve this, any ideas? Thx for replying before. Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted January 20, 2009 Share Posted January 20, 2009 If you have 2009, I don't, but wouldn't the new spline mapping do the job w/o having to remodel? Just extract that loop and walla. Either smooth or linear as needed? Link to comment Share on other sites More sharing options...
leoviale Posted January 20, 2009 Author Share Posted January 20, 2009 Man, that's amazing, never knew about that. I found this. I'll give it a try. Thx. Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted January 21, 2009 Share Posted January 21, 2009 Which is, I think, straight from Autodesk web site is also instructive in terms of pointing out some of the control you have over the cross section points (which I think the still you posted could benefit from. A couple places the looked like some rotation would really help). One of the benefits of being poor. Unlike rich people who go "oh, new version" and get it then immediately go about using it exactly the same way they did before (except probably for sky portals, those have probably been snapped up like nobody's business) I get to sit around for years reading the new features lists over and over again with a wistful look in my eye. Over the course of that, the spline mapping stood out. Link to comment Share on other sites More sharing options...
