Regathering question...
quizzy
Standard MAX radiosity; regathering = on And this is what happens in frames 586 and 587: 587 is darker in the glass of the painting, I've used a standard raytrace material without fresnel effect. Another thing is: when rendering this animation, some frames just stop rendering. And allthough my camera is the only thing that animates, after frame 0 it says that my solution is invalid.... strange.....
images:
this could be a regathering problem, as it calculate about the camera position...i dont see that regathering is generating the best it can in your image so what about turn it off and set the quality higher and mesh lower? I could save your render time.
About the invalid solution i think its a bug of Max because i was rendering an animation (like you, only my camera was animated)and it happened here...you can turn off the "compute advanced lighting when required" on render dialog and let it renders.
