paj Posted January 21, 2009 Share Posted January 21, 2009 I have been using Accurender for the last 10 years as an Architectural Visualiser (AutoCAD to model). I'm now looking other rendering software to give a more realistic result, but still using AutoCAD to model. Can anyone suggest an alternative which has a fast learning curve? Thanks. Link to comment Share on other sites More sharing options...
frank1331 Posted January 21, 2009 Share Posted January 21, 2009 I'm not sure if there is anything that has a fast learning curve, but I wouls reccomend 3D Max. You can still do the majority of your modeling in AutoCAD, and then bring the model into Max. I used to use Accurender, and made the switch 8 years ago. I was also looking for more realistic renderings. But because it is a more complex program, there is a bit or a learning curve. Good luck. Link to comment Share on other sites More sharing options...
ihabkal Posted January 21, 2009 Share Posted January 21, 2009 Form a quick search on yahoo I found this http://blog.miragestudio7.com/2007/02/autocad-2008-let-there-be-lights-and-materials/ so Mental ray for Autocad, it is a little harder to learn than other renderers, but if you master it then if you move to max, maya or softimage and use it there you would have a good jumpstart. Link to comment Share on other sites More sharing options...
Antisthenes Posted January 21, 2009 Share Posted January 21, 2009 accurender nXt http://nxt.accurender.com/ it is allot better than the other accurender, flamingo users are envious because flamingo nXt is not avail. Then again Brazil (free currently) and Vray are fast and dominant currently. Link to comment Share on other sites More sharing options...
paj Posted January 22, 2009 Author Share Posted January 22, 2009 Had a look at NXT but still in it's beta testing stage. Can you pull an AutoCAD drawing into Brazil? Link to comment Share on other sites More sharing options...
Antisthenes Posted February 17, 2009 Share Posted February 17, 2009 sure Link to comment Share on other sites More sharing options...
AJLynn Posted February 17, 2009 Share Posted February 17, 2009 That didn't make sense. Brazil is a renderer, not a full 3D package - you can't go Autocad to Brazil, you would need to go Autocad to Max/Rhino to Brazil. Link to comment Share on other sites More sharing options...
Antisthenes Posted February 18, 2009 Share Posted February 18, 2009 i assume he meant Rhinoceros with the currently(not for long) free for commercial use Brazil plugin opening autocad files you might want to use ACISout or a combination of that and DWG to avoid meshing your primitives if you have any as your model nXt for autocad only currently i like how it does the reverse of maxwell and fryrender have you played with Penguin 2 Sr1 that is for acad also? and combined with accurender nxt could make a nice hybrid render. Link to comment Share on other sites More sharing options...
AJLynn Posted February 18, 2009 Share Posted February 18, 2009 I think that only you would read that and assume he was a Rhino user Link to comment Share on other sites More sharing options...
Antisthenes Posted February 18, 2009 Share Posted February 18, 2009 it's McNeels product, if he said Flamingo i would think he meant that. but since he said Brazil and Rhino is where i know that to be and us it, that being the one with, in my opinion, a very easy "fast learning curve" for any acad user... accurender is for revit or autocad, i know Link to comment Share on other sites More sharing options...
akinlolugboji Posted April 17, 2010 Share Posted April 17, 2010 Will still stick with Accurender but Artlantis has gentle learning curve. Give it a try. Link to comment Share on other sites More sharing options...
