ADT blocks library
ihabkal
Friends,
A Lebanese friend of mine, desparatley needs Autocad Architectural Desktop /Autocad Architecture blocks: desks, doors, chairs, of good quality and a library that loads fast and is easy to work with and doesn't overload his system (not 5000 polys per desk).
Can anyone give me a few links to commercial providers?
Thanks.
http://ftp.icm.edu.pl/packages/winsite/winxp/graphics/progeCADprogeARCH.exe
this says
Architectural AutoCAD Clone Software, no learning curve for AutoCAD users, Natively reads and writes AutoCAD DWG files, no need for conversion! Includes Walls Doors, Windows with trim and cleanup, stair plans, sections, and ceiling patterns. Room, Door and Window schedules, furniture, plumbing, HVAC, lighting and power symbols. Draw parking stalls, create details and elevations, everything needed for construction drawings. Industry standard AutoCAD Commands. AutoCAD Menu, Script, Font Compatibility, AutoLISP Compatibility! Advanced Rendering Options, 3D ACIS Solid Modeling included. Import and edit your Raster Images, including Raster to Vector. Comes with near 10,000 standard symbols and blocks. An easy replacement for AutoCAD and AutoCAD LT! AutoCAD DWG File 2.5 - 2008 Open and Save Compatible with AutoCAD menus, scripts, fonts, etc. Compatible with AutoLISP, ADS, VBA and COM.
maybe those 10,000 blocks from this demo are compatible, about to test
i know you can always build your own but i have never done this, Multi-View blocks
Creating a Multi-View Block
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=2331594
here is a offering from ArchVision
http://www.archvision.com/Autodesk_Content/2008.cfm
(link for "Over 500 Free Multi-View Blocks" )
