Parametric gemetry linking
YOHKOH
Hi
Does anyone know a way of linking two boxes together so that when i changed the size of one, using the length/width paramteres the other will move its postion to stickwith a surface.
Does this make sense. So if i had a tower with a box on top of it. I change the height of the tower in the height parameter and the box on top moves up or down..
Ta
Sure, you can wire controls for just about any parameter in max. The following is a tutorial that is applied to wiring a character model in max, but I've used the process before to make controls for animating a lifting patient bed in max. I'm sure you could apply the same method to changing your tower.
http://area.autodesk.com/index.php/tutorials/tutorial_index/wiring_a_control_board_in_3d_studio_max/
