Arquitetura3d Posted August 18, 2003 Share Posted August 18, 2003 I NEED HELP TO BUILD A REAL ROOF NOT THE PLANNAR ROOF WITH MAP IN TEXTURE I NEED THE REAL ROOF? HOW TO BUILD IN MAX? Link to comment Share on other sites More sharing options...
David Barbarash Posted August 18, 2003 Share Posted August 18, 2003 Hmm.. well the obvious answer would be to model it. This of course depends on what kind of roof it is. Cedar shakes? Asphalt shingles? Slate? Spanish tile? Be a bit more descriptive and we may be able to help... David Barbarash Link to comment Share on other sites More sharing options...
Arquitetura3d Posted August 18, 2003 Author Share Posted August 18, 2003 Hi david. thx for reply my question. i work with spanish roofs and some slats. did you know how? tHx in advance. Link to comment Share on other sites More sharing options...
mbr Posted August 18, 2003 Share Posted August 18, 2003 Try a search on here. I vaguely recall there being a discussion about it a while back. Link to comment Share on other sites More sharing options...
LKlemenc Posted August 19, 2003 Share Posted August 19, 2003 Here is one tutorial I once made for a Slovenian 3D/2D page. It's written in Slovene language, but I think it's quiet understandable (all major words are bold). The trick is that you attach all your tiles to one single mesh and assign MaterialbyElement modifier. Hope that halps somehow Link to comment Share on other sites More sharing options...
Sergio Posted October 16, 2003 Share Posted October 16, 2003 Hi LKlemenc! your tutorial looks very interesting. Only one thing I could not figger out, and that is in points 5 and 6, how do you apply material, and colouring different tiles in different colours? Regards Sergio! Link to comment Share on other sites More sharing options...
kid Posted October 16, 2003 Share Posted October 16, 2003 Quote Originally posted by Sergio: ... Only one thing I could not figger out, and that is in points 5 and 6, how do you apply material, and colouring different tiles in different colours? Quote Originally posted by LKlemenc: The trick is that you attach all your tiles to one single mesh and assign MaterialbyElement modifier.and the material is a Multi/Sub-Object material. When you attach all the tiles together each tile becomes an element of that object. Link to comment Share on other sites More sharing options...
Sergio Posted October 16, 2003 Share Posted October 16, 2003 thanx kid! how to atach to single mesh by using boolean union? Link to comment Share on other sites More sharing options...
STRAT Posted October 16, 2003 Share Posted October 16, 2003 http://www.anteropedras.com/nrb/tut_rooftop.html Link to comment Share on other sites More sharing options...
Sergio Posted October 16, 2003 Share Posted October 16, 2003 Thanx guys, I worked it out! these are kewl tuts. Regards Sergio! Link to comment Share on other sites More sharing options...
DelfoZ Posted October 16, 2003 Share Posted October 16, 2003 to ATTACH a single MESH objet to other 1.-Convert it to Editable MESH if the objet isnt a mesh 2.- go to MODIFY/ scroll it to EDIT GEOMETRY and click ATTACH or ATTACH LIST... and DOne.. ** Don't use Boolean to atach Link to comment Share on other sites More sharing options...
Sergio Posted October 16, 2003 Share Posted October 16, 2003 Thanx DelfoZ! Boolean is so bad and gives so much trouble... there were some articles against boolean, so many times I lost,due to using boolean,some faces, while making window openings... Some people refer to non free Power Boolean plug in; wich demo I downloaded, it is also making mess... Link to comment Share on other sites More sharing options...
