Noise Posted January 27, 2009 Share Posted January 27, 2009 Hi What is up when Back Burner errors and says - 'Output Path' ? Then lists an output path which is perfectly valid from that machine using UNC paths. Thanks N Link to comment Share on other sites More sharing options...
Oleksandr Kramer Posted August 8, 2009 Share Posted August 8, 2009 Check security settings for your network path (enable read and write to your network folder) I prefer to add the BB server to startup system folder. Not use BB as system services. Link to comment Share on other sites More sharing options...
Dave Buchhofer Posted August 8, 2009 Share Posted August 8, 2009 if backburner server is run as a service, you may need to supply a login for it that has network access. Link to comment Share on other sites More sharing options...
