Vray DR Problem, can't find a useful help or link
Wandeegroup
To be honest I can't say exactly why DR isn't working in your situation but I believe it is probably because you’re reaching a limit to how much data Vray can realistically handle. It could also be that your network is simply to slow to be able to push 4,8, or 12 GB of data to 20 render nodes in a reasonable amount of time and therefore they simply time out. I agree that it doesn’t seem to be a memory problem so it must be an issue in the network setup.
After looking as some of your scenes I'm surprised that your memory requirements are so high. My first question would be are you using proxies in your scenes, if not that could be the source of your incredibly large files. I routinely work on projects with thousands of proxies in them and I rarely use more than 4 GB of ram.
Mario I have to ask why do you need all of that detail in a rendering; I would think that most of it wouldn’t even show up. It sounds like you are modeling everything as it would be constructed, but I can tell you that even though it might be perfect for doing construction drawings from it's really over kill for a rendering.
