Vertex link script
YOHKOH
Hi does anyone hace script which will link the vertex's on an object to the position of another object. I want the face of my object to follow the movement of a point helper.
Thanks
I tried the kinko2v from 3d lurv but couldn't get it to run properly
You don't need a script there is a modifier called Linked Xform. If you use a mesh select modifier to pick your verts or faces that you want to link then add the linked xform modifier whilst still in sub-object mode you can link these to any control object you wish.
