Crazy Homeless Guy Posted January 31, 2009 Share Posted January 31, 2009 I am always browsing ScriptSpot, and a few other places for scripts that will make me more efficient. I found this one today, and so far it works like a charm. I often have 2 or 3 copies of max open, and I often have to save selected, and merge that information into the scene I am working on. This script will allow you to copy and paste between open copies of Max. http://www.scriptspot.com/3ds-max/copy-and-paste-objects Link to comment Share on other sites More sharing options...
Horhe Posted January 31, 2009 Share Posted January 31, 2009 (edited) Thanks Travis, always on the lookout for good scripts and plugins. Edited February 1, 2009 by Horhe Link to comment Share on other sites More sharing options...
Tim Nelson Posted January 31, 2009 Share Posted January 31, 2009 Awesome! I can't believe Max does not let you do this already, it has always bugged me. Link to comment Share on other sites More sharing options...
Chad Warner Posted February 1, 2009 Share Posted February 1, 2009 That's a great find! Link to comment Share on other sites More sharing options...
cgrant3d Posted February 2, 2009 Share Posted February 2, 2009 (edited) I am always browsing ScriptSpot, and a few other places for scripts that will make me more efficient. I found this one today, and so far it works like a charm. I often have 2 or 3 copies of max open, and I often have to save selected, and merge that information into the scene I am working on. This script will allow you to copy and paste between open copies of Max. Hey guys - glad to see my script is still useful. :-) I actually have been working with multiple instances of max as part of my daily workflow for years now - I use the script every day to copy / paste objects. My workflow is to have my master file open, copy an object or two out of it (say a huge revit file) and paste into a new, clean file where I work on it and then copy/paste it back to the original file. Edited February 3, 2009 by cgrant3d Link to comment Share on other sites More sharing options...
Trevor Tizard Posted February 3, 2009 Share Posted February 3, 2009 Hi, Looks like a great script. There is no mention as to whether it will work with max2009 though? Thanks. Link to comment Share on other sites More sharing options...
Tim Nelson Posted February 3, 2009 Share Posted February 3, 2009 I think he had made a comment on scriptspot about it being forward compatible. Anyways, yes it works on 2009 perfectly. Link to comment Share on other sites More sharing options...
anvaraziz Posted February 3, 2009 Share Posted February 3, 2009 ahhh thats gonna save a lot of time,,, thanks Link to comment Share on other sites More sharing options...
Tim Nelson Posted February 3, 2009 Share Posted February 3, 2009 Yea I've already used it a ton just in the past couple days. Link to comment Share on other sites More sharing options...
cgrant3d Posted February 3, 2009 Share Posted February 3, 2009 Hi, Looks like a great script. There is no mention as to whether it will work with max2009 though? Thanks. Thanks for pointing this out - I've updated the post on ScriptSpot to reflect current version compatibility. FYI - in nearly all cases scripts are forward compatible. Link to comment Share on other sites More sharing options...
Tim Nelson Posted February 17, 2009 Share Posted February 17, 2009 I don't suppose it'd be possible to write a script which would allow you to paste in linework from autocad that you have copied to the clipboard, would it? It's a pain when you only want certain parts of a dwg to be imported into max. I usually just w-block out those items, and then import to max, but it would be great to have a copy/paste from acad->max. Link to comment Share on other sites More sharing options...
cgrant3d Posted February 17, 2009 Share Posted February 17, 2009 I don't suppose it'd be possible to write a script which would allow you to paste in linework from autocad that you have copied to the clipboard, would it? It's a pain when you only want certain parts of a dwg to be imported into max. I usually just w-block out those items, and then import to max, but it would be great to have a copy/paste from acad->max. Sorry - the script actually doesn't touch the windows clipboard at all and 3ds doesn't have any way to read geometry from the clipboard (that I know of at least). It would be nice to be able to interact between different autodesk apps though... Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted March 7, 2011 Author Share Posted March 7, 2011 Chris, I want to thank you again for the copy and paste script, I use it nearly everyday. I also I wanted to post another script that popped up today that is very similar. I will wind up using both in my workflow. The new one allows you to store 3 various geometry sets for pasting. http://www.scriptspot.com/3ds-max/scripts/copitor I think he should have given Chris credit for the idea though. Link to comment Share on other sites More sharing options...
BrianKitts Posted March 7, 2011 Share Posted March 7, 2011 (edited) Chris, I want to thank you again for the copy and paste script, I use it nearly everyday. +1! I could never go back to my old workflow for pulling geometry from old models after I got started with the copy paste script. Edited March 7, 2011 by BrianKitts Link to comment Share on other sites More sharing options...
