Paul Twyman Posted February 3, 2009 Share Posted February 3, 2009 Hey, Has anyone else had this problem? I'm using max 2009 Design I found the following thread on here but no solution. http://www.cgarchitect.com/vb/30558-no-render-preview.html One minute it is fine then I go to use it again and nothing happens, it just appears black. (it's not just that my exposure setting are to low) It doesn't work with any of the exposure controls. I have been putting up with it for awhile but it's getting really annoying now am I doing something really stupid!!!! Link to comment Share on other sites More sharing options...
Paul Twyman Posted February 3, 2009 Author Share Posted February 3, 2009 Just found a way to fix it so I am guessing it is something to do with mental ray. Just changed renderer to scanline to see if it worked ok then and it did. Then changed it back and now it is fine again. Must have reset something in Mental Ray. Link to comment Share on other sites More sharing options...
pfbreton Posted February 4, 2009 Share Posted February 4, 2009 An unfortunate bug related to mental ray causes this: when using too low antialiasing settings, its turing black. Increase the sampling quality for the preview and it will go back to normal Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted February 4, 2009 Share Posted February 4, 2009 Woo, Pierre, thank you. I'll add that turning up minimum before maximum is worth doing. Link to comment Share on other sites More sharing options...
Paul Twyman Posted February 4, 2009 Author Share Posted February 4, 2009 Brilliant, Thank you Link to comment Share on other sites More sharing options...
ankit4d Posted February 4, 2009 Share Posted February 4, 2009 I was also facing this problem last week, thanks for the solution...it works. Link to comment Share on other sites More sharing options...
Cesar R Posted December 20, 2010 Share Posted December 20, 2010 An unfortunate bug related to mental ray causes this: when using too low antialiasing settings, its turing black. Increase the sampling quality for the preview and it will go back to normal Hi where and how do you change this? I am having the same issue is several scenes and I am going crazy. help please. Link to comment Share on other sites More sharing options...
Paul Twyman Posted December 20, 2010 Author Share Posted December 20, 2010 Hi, Just your normal sampling settings, min and max in the render dialogue. There are no preview specific ones. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Cesar R Posted December 20, 2010 Share Posted December 20, 2010 For some reason this did not work for me unless I am so lost that I am playing w the wrong setting. Link to comment Share on other sites More sharing options...
Paul Twyman Posted December 20, 2010 Author Share Posted December 20, 2010 Have you tried changing to scanline renderer and back again to see if it fixes it? If that doesn't work I'd probably suggest that it might be something to do with your settings. Does it look ok when you do a normal draft render through the frame buffer? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Cesar R Posted December 20, 2010 Share Posted December 20, 2010 ^ that works, but it completly messed up my MR settings. and I have to re-configure everything again. Link to comment Share on other sites More sharing options...
Paul Twyman Posted December 20, 2010 Author Share Posted December 20, 2010 Do you not have a previous scene you can save a preset from and import? (look in your autoback if not) Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Cesar R Posted December 20, 2010 Share Posted December 20, 2010 um.. preset for Gi and FG settings? - you can save those to a file? Link to comment Share on other sites More sharing options...
Paul Twyman Posted December 20, 2010 Author Share Posted December 20, 2010 At the bottom next to the big Render button. Open up drop down and save/load preset. Will give you option of what to save. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
