@lkion O Posted February 3, 2003 Share Posted February 3, 2003 Hello ppl Im still at the begining of this but thanks to Quizzy i ve made a lot of progress!!i finally managed to use hdr images with a seperate background. For this im using a skylight in max 5 and a seperate hdr as enviroment,but there is someting wrong in the rendering http://www.cgarchitect.com/forum/filepush.asp?file=qwe.jpg PLEASE HELP!!! 1) It needs moreeeee antialising- is there any way? to make the spheres more smooth except from increasing their segments? 2)How do it get reed off that blurry tabletop? Thanks Link to comment Share on other sites More sharing options...
Christopher Nichols Posted February 3, 2003 Share Posted February 3, 2003 The problem is not the anti-aliasing, but the samples... you want smaller samples a lot lot more of them... you are using the light-tracer I am assuming... if so what are your settings? Specifically, what is the min-max sample size and what is the number of samples? You will want your number od samples to be around 64 to 128 to get something smooth... BTW, your rendering times will go WAY up... so be warned. Link to comment Share on other sites More sharing options...
@lkion O Posted February 3, 2003 Author Share Posted February 3, 2003 These are the settings http://www.cgarchitect.com/forum/filepush.asp?file=pr1.jpg How do i change the min and max samples? Link to comment Share on other sites More sharing options...
nisus Posted February 4, 2003 Share Posted February 4, 2003 Change the amount of rays... Maybe add a few more bounces too, because reflections and glass need more rgds nisus Link to comment Share on other sites More sharing options...
@lkion O Posted February 4, 2003 Author Share Posted February 4, 2003 Thank you nisus Here is a jpeg with rays set to 500 http://www.cgarchitect.com/forum/filepush.asp?file=tile3.jpg Comments pleaseeee! Thank for the warning of rendering time. But seriously why is taking so long? It took 5 minutes to render it!!! with raytrace materials and i know for sure that the same scene in C4D would take half the time. Is there any explanation? Link to comment Share on other sites More sharing options...
Christopher Nichols Posted February 4, 2003 Share Posted February 4, 2003 simple explanation... the light tracer is basically unusable... if you want to use GI with a system like light tracer, use Brazil or Vray. You can try Vray for free. Your render time for something like that would take about 25 seconds. Link to comment Share on other sites More sharing options...
@lkion O Posted February 4, 2003 Author Share Posted February 4, 2003 Ok thank you Christopher! I'll post the results... Link to comment Share on other sites More sharing options...
