good outside daylight??
cjhunter
Hi
Ive been trying to set up realistic daylighting, and Ive simply tried the "daylighting" system, which looks great..but Im sure theres ways to get better results...Is doing a light dome better? Ive also tried a direct spot light to mimick the sun in combination with a skylight to difuse light. I would like to have shadows that are somewhat sharp. Any suggestions? thanks!
If your using vray, use the vray sun and vray sky...if your using Mentalray, use the MR sun and MR sky....
When using this in vray...you need to use a physical camera...
And in Mentalray...you need to use exposure with the outside daylight box checked...
