danb4026 Posted February 6, 2009 Share Posted February 6, 2009 I have been using a linear workflow for quite some time now: Under Preference I set Gamma as follows -Gamma and LUT Correction Enabled - set to 2.2 gamma -Material Editor and and Color Selectors affected -Bitmap input and output files remain at 1.0; when I add a material to the material editor I apply a 2.2 gamma to it, or use color correction to set to 2.2. When I save a file, I also save with a 2.2 Gamma. With this workflow, one is supposed to use Linear Color Mapping and set the Gamma to 2.2 aswell. This I do. The problem is, that all renderings come out washed out, even with materials previously having their gamma set to 2.2. I find myself having to change the gamma in linear color mapping down to 1.8 or less, sometimes even 1, to get a vibrant render. If I were following the Linear Workflow properly, I do not think I should have to adjust the color mapping like I am. Am I doing something wrong or have I missed something? Link to comment Share on other sites More sharing options...
ihabkal Posted February 6, 2009 Share Posted February 6, 2009 I have been working linear for over a year and things were never easier. You should darken your materials not lighten them. When you set them to 2.2 you are making them brighter, you should set them to .4545 Link to comment Share on other sites More sharing options...
danb4026 Posted February 6, 2009 Author Share Posted February 6, 2009 (edited) Ihab, Then what are your settings? Should I set Gamma in preferences to 2.2, input bitmaps to 2.2 aswell and then set the linear color mapping to .4545? These settings seem to make all colors match (material editor slots, "view image" in the editor and rendered image). I have been working linear for over a year and things were never easier. You should darken your materials not lighten them. When you set them to 2.2 you are making them brighter, you should set them to .4545 Edited February 6, 2009 by danb4026 Link to comment Share on other sites More sharing options...
danb4026 Posted February 7, 2009 Author Share Posted February 7, 2009 (edited) If you can see the attachment...these are the settings that seem to work for me. Edited February 7, 2009 by danb4026 add attachment Link to comment Share on other sites More sharing options...
DavidR Posted February 7, 2009 Share Posted February 7, 2009 If you can see the attachment...these are the settings that seem to work for me. The smaller image is too lo-rez to read -can you post a higher-res version? thanks. Link to comment Share on other sites More sharing options...
danb4026 Posted February 7, 2009 Author Share Posted February 7, 2009 hopefully this is better Link to comment Share on other sites More sharing options...
ihabkal Posted February 7, 2009 Share Posted February 7, 2009 you darken your images in photoshop using gamma .4545 or use color correction material with gamma .4545. max gamma is for display only and doesn't affect the images. Link to comment Share on other sites More sharing options...
