HAL-E Posted February 6, 2009 Share Posted February 6, 2009 Does anybody know where these strange stains on my glass come from? the model should be fine, as well as the material settings (refl. / refr. glossiness = 1, fresnel ior 1.6, max depth 10, options: reflect on backside) scene rendered with hdri (vray dome light) rendersettings: no reflective gi caustics, 1.bounces irr map. 2.bounces brute force, dmc sampler: adaptive amount: 0.85, noise threshold: 0.002, min samples: 8 thanks for any help! Link to comment Share on other sites More sharing options...
Thablanch Posted February 8, 2009 Share Posted February 8, 2009 I know you said the model is fine, but can you still show a wireframe screenshoot.... Really looks like a model issue Link to comment Share on other sites More sharing options...
HAL-E Posted February 8, 2009 Author Share Posted February 8, 2009 Ok, here's some screenshots of the model. It's an editable poly, all the vertices are weld... Link to comment Share on other sites More sharing options...
Joseph Petrino Posted February 9, 2009 Share Posted February 9, 2009 It might be a coplaner face issue. Try upping your "Secondary rays bias" setting a bit. Link to comment Share on other sites More sharing options...
HAL-E Posted February 9, 2009 Author Share Posted February 9, 2009 I just enhanced the secondary rays bias but the rendering still looks the same. Link to comment Share on other sites More sharing options...
Craig Ramsay Posted February 19, 2009 Share Posted February 19, 2009 In your glass material, what is the max depth set to for refraction? You'll probably want to go higher than the default setting of 5 for that model. Link to comment Share on other sites More sharing options...
HAL-E Posted February 21, 2009 Author Share Posted February 21, 2009 Thanks for your suggestions. My glass material has a refraction max depth of 10. But now i found out that it was a smoothing group issue (look at the attachments). In my opinion, smoothing group angle 10 looks best. cheers! Link to comment Share on other sites More sharing options...
