huntch3 Posted February 8, 2009 Share Posted February 8, 2009 Hi I've been trying to apply a bitmap to an object, but some reason its not working...Settings are on UV, but do I need to change the render setting to Mental ray, or some specific reder type setting? When I try to drag the bit map, th icon with a circle with a slash through it apears...any suggestions? thanks.... Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted February 8, 2009 Share Posted February 8, 2009 I wonder if you have a selection filter on. Up on the toolbar towards the left is a dropdown with "all, geometry, lights..." in it. If you have that set to something that doesn't allow you to select geometry then you won't be able to drop a jpeg on geometry. Link to comment Share on other sites More sharing options...
