Noise Posted February 9, 2009 Share Posted February 9, 2009 Hi I am creating a simple animation in max by moving the camera to create the keyframes. When I replay the camera it speeds up between keyframes then slows down when it gets to the next keyframe - then speeds up then down at the key frame - so on and so forth. Is there a way to make the speed more constant around each keyframe without having a massive knock on effect to the other keyframes ? thanks N Link to comment Share on other sites More sharing options...
Dave Buckley Posted February 9, 2009 Share Posted February 9, 2009 i think you can do it in the track view editor, there is an option for linear, by default i think it is on ease in and out Link to comment Share on other sites More sharing options...
JonRashid Posted February 9, 2009 Share Posted February 9, 2009 You can also right click on the key in the track view Link to comment Share on other sites More sharing options...
