Adding a texture to a curved wall?
jcsDesigns
Hi
Could anyone please help me in solving this headache! I have a curved wall 2m high and 1.7 in the curved length. I am trying to add an image to the face, the image is the same size has the wall, but! when I apply this it looks incorrect? why is this and how could I solve the problem.
Many Thanks
You have a couple of options. Put a cylindrical map on the object making sure the centre of the map is at the centre of your arc. You will then have to tweak the v repeat on your mapping coords. If you switch display map on you can do this interactively until it is correct.
Alternatively you could extrude the object with generate mapping coords on. This should place your map perfectly without repeat adjustments
