background "projected"
yoksomin
Hi everyone:
I have a problem with an render, and after tryed some tutorials and searches...nothing yet.
Iam making an exterior render with Vraysun and a map in "enviromment" (key 8)
As you can see in this very low render, my enviromment map its "projected" on my "shadow wall", and i dont want this.Why this happen?:(
Render 1:
When i render only with Vraysun and Vraysky on "enviromment" (key8), that doesnt happen, but all the glass reflections disapears.
Render 2:
So..i'll liked to have that "background" image with glass reflections, but how can i make it, without have that "projection"?
Best regards,
Hi,
First of all, many thanks:)
I just put the map on the enviromment (key 8)..i didnt set the map.
After you help me, i drag and drop the "enviromment map" to the material editor and change the "screen mode" to "spherical mode" and the result was this:
render:
Well, the "projection" desapear, but the background map modifies and the reflections to.:(
Why?How can i have the same background map and the reflections?without that wall "projections"?
This wall doesnt have reflections;)
Best regards
Hi,
Once again, many thanks:)
Even i dont have a good hdri image, iam gonna try it:)
Ill post the result soon...i hope so, if i get a good hdri image:)
By the way, where can i get good hdri images?
Thanks,
Best regards
Edited by yoksomin
Hi,
Thanks to all!
After read all the opinions,i´ve tried this...
In this render i use "mattclinch" idea, and i put a enviroment map using "espherical" set, just to have the background map without those "wall projections"....thanks
After i use the "mhmd19732008" idea, using a "fallof" map for reflection.Thanks
The result i think its nice.For me of course, iam a beginner.
Result (not final,because its very low render):
Next, i'll get some HDRI images, and gonna try the "mhmd19732008" idea.Thanks again!!:)
By the way, what you think about this image?Lighting..grass(fur)..etc?:)Some opinions will be great:)
Best regards
1-use a vray camera, enable vigeniting, DOF.
2-use a mapscaler modifier for granite wall.
3-use vraydisplacement modifier for gras, use a good map for displacement.
4-add some trees, also flowers and shrubs infront of shot will be more realistic.
5-add figures.
6-make frames for windows.
7-put some interior opacity maps behind windows.
8-add lighting fixtures.
9-for GI, use IM for pri. bounces and None for sec. bounces, avoid LC in exterior renderings.
hope works.....
Hi,
Thanks once more:)
That was an unfinished work, and now iam gonna try those ideas "mhmd19732008".
I have already mapscaler for granite wall,vraydisplacement modifier for gras:)
By the way, how can i put some figures?I make an opacity map, make a plane to this map, but seems like a "double image"/"mirrored" when i render it...very strange,to me :)
best regards,
Edited by yoksomin
Hi,
After "mhmd19732008" ideas, i made another test render.
1- IM for pri. bounces and None for sec. bounces
2 - some trees, also flowers and shrubs infront of shot
3 - Vraydisplacement on granite wall, but i dont know why in the edges apear those "black lines".(how can i fix that?)
I didnt put some figures because i dont know how:(
render:
Sorry about all my questions, but i dont know how i can fix them.
Thanks
Best regards
Hi "mhmd19732008":)
Sorry but i didnt understand:(.."1-remove fallof from figure plane"?where?
I dont have any fallopf..anywhere..
Ok, using a 3D figure its better, but this is one thing i would like it to know....please
This is a poly plane...with the opacity and difuse map.this is only a two persons map,but appear four heheheh
This is only a teste render to see the result (bad hehe).
render:
I have more and better figures..and this would help me very much, to make put some dynamic on my works...
Best regards
